Author Topic: coil springs  (Read 1968 times)
linfordland
  • Yorkshire
    • CDX diesel auto
coil springs
« on: 29 March 2015, 19:01:06 »
Hello there.  I'm wanting to lowering my omega and im wondering if vectra c coil springs will fit as I've been offered a set.
Any advice?   Thanks.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: coil springs
« Reply #1 on: 29 March 2015, 19:22:51 »
Whoever offered them, is doing you no favours at all.
No, they are not suitable.
linfordland
  • Yorkshire
    • CDX diesel auto
Re: coil springs
« Reply #2 on: 29 March 2015, 19:27:09 »
Thanks for the info.  My friend said he didn't know if they fitted.
chrisgixer
  • Woking ham
  • Banned
Re: coil springs
« Reply #3 on: 29 March 2015, 19:30:02 »
Then he's no friend. Always fit the correct springs. :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: coil springs
« Reply #4 on: 29 March 2015, 20:40:35 »
Bit of a harsh reply.
His friend offered,and wasn't sure if they would fit,the op was looking for some helpful,and friendly advice.
Hoof'land storeman.
chrisgixer
  • Woking ham
  • Banned
Re: coil springs
« Reply #5 on: 29 March 2015, 20:59:19 »
Possibly. Depends on the likely hood of causing an incident if fitted. There needs to be no doubt. Imo. :) isn't that right, Mr Pot. :D
Re: coil springs
« Reply #6 on: 29 March 2015, 21:15:04 »
Certainly Mr Kettle... ::)
The issue is that although they might appear to be the same length or diameter,  they will be wound to suit a very specific weight band for any given car... so otherwise identical cars with different engines will have different springs, and that's before you start on models... sri/gsi/gls etc...
So for the Omega, estate front springs are potentially different to saloon ones, rears are definitely different, and then they will be different for each engine type, 4 cyl petrol/v6 petrol/4 cyl diesel/6 cyl diesel all have different front springs for each body type...
You don't say which diesel your car has, or if it's saloon or estate, but as there is/was no sports diesel model officially your only choice would be Irmscher or speaking to someone like Balance Motorsport and source a set of lowering springs, possibly to order, to suit your exact max axle weights/gross vehicle weight :-\
« Last Edit: 29 March 2015, 21:18:55 by Taxi Al »
chrisgixer
  • Woking ham
  • Banned
Re: coil springs
« Reply #7 on: 29 March 2015, 21:30:08 »
So, as Mr Black suggests ::)
going even further astray to another model is asking for trouble.
linfordland
  • Yorkshire
    • CDX diesel auto
Re: coil springs
« Reply #8 on: 30 March 2015, 10:03:46 »
Its a saloon. Thanks i didn't realise there was so many variants.  I'll stick to specific model lowering springs.
chrisgixer
  • Woking ham
  • Banned
Re: coil springs
« Reply #9 on: 30 March 2015, 10:43:56 »
Re: coil springs
« Reply #10 on: 30 March 2015, 13:47:36 »
Yes, stick to the ones designed for the Omega. Not only is the weight an issue, but the car balance will be completely different to a FWD.
