Door pins
Started by EMD, 10 April 2015, 14:03:53
chrisgixer
Plus if being pedantic to that level, arguably ::) ;D the red tab will get damaged slightly on removal. Just make people aware.
You don't need to remove the tab... You can also remove the door card and unscrew the pin... But why complicate things ;D
chrisgixer
Quote from: Taxi Al on 14 April 2015, 15:12:38
Because.... The red tab will get damaged. ::) ;D
 ;D I guess then the real question is which would be more annoying... ::)
chrisgixer
Depends if the owner can wait until the door card needs to come off.
...then replace the door motor, as the guide, and completely forget about the rattling poxy door pin ;D
steve6367
Quote from: chrisgixer on 14 April 2015, 15:02:06
I managed to keep mine completely unmarked - which is unusual!
chrisgixer
What did you use? I find a knife gives best odds.
EMD
Quote from: chrisgixer on 14 April 2015, 15:41:43
That was going to be my next question  :( I used a stanley blade .. seems its not that though .
The passenger seat is rattling when no one sits in it  ::)
Omegatitis
Quote from: EMD on 14 April 2015, 19:30:38
Check the two screws under the rear pocket panel and that the four seat bolts are secure :y
EMD
Quote from: Taxi Al on 14 April 2015, 20:11:50
Ok , will get there in the end  ;D Ill here a pin drop when the rear wheel bearing is fixed tomorrow  ::)
Omegatitis
steve6367
A very fine screwdriver and changed up once I had an edge  :y
Mr.OmegaMan
Don't get me started on rattles an squeaks  ;D
Have had all kinds on the FL Elite while most are now cured a few remain here's a few over the years I've found.... Centre air vents, rear seat belts, arm rest, steering column, drivers air vent/housing, transmission handle/sports mode button, glovebox, creaking rubber when windy passenger drivers door area, cd multi-changer metal plate something there rattles and it's not the plastic 4-stack holder, ummm that's about it  :o... Saying that I'm ultra fussy about rattles so I'm told anyway  ::)
EMD
Quote from: Mr.OmegaMan on 15 April 2015, 23:32:00
Too many screws holding the elite together you see  :)
Omegatitis
steve6367
How did you stop the transmission handle?
You can't really as the rattle is likely the selector release cable :-\
This runs through the handle shaft...
