Electrical question
Started by Kate, 05 May 2015, 18:48:09
Kate
Hi all.
I've just bought a used range cooker off gumtree. It's dual fuel - gas and electric.
Should I use 10mm twin and earth to wire it or would 6mm be better?
It's a Stoves Newhome DFDL I think, with 2 ovens and a grill. The hobs are gas.
Any advice would be greatly appreciated. :y
Thanks.
Kate
MV6Gaz
Have a gander at this re cabling and fuses
http://www.diynot.com/forums/viewtopic.php?t=81205
Amps=watts/voltage
Happy cooking :y
Did you get your alternator sorted?
05 Volvo S80 D5, 98 V70 TDI, 99 V70 SE
Kate
Quote from: MV6Gaz on 05 May 2015, 19:41:31
Amps=watts/voltage
Happy cooking :y
Thanks very much. :y
Yes I bought an alternator off eBay for £28 and the garage in my street fitted it for £50. :)
A big thanks to Kevin Wood for diagnosing the problem. :y
Kate
On the back of the cooker it says 22.8KW.
Would that mean it's 95A?
hercules
have you got the decimal point right
Kate
Quote from: hercules on 05 May 2015, 20:10:44
Yes that's right but I'm guessing that's the total including the 8 gas burners.
I had another look on the back and in small writing it says 4205W total which I assume is for the 2 ovens and the grill.
hercules
Quote from: Kate on 05 May 2015, 20:18:03
gonna say 22800 watts is a tad high  :) for the electric side
Kate
So 6mm should be enough shouldn't it?
MV6Gaz
30 amp connection and 6mm twin and earth, from the Stoves website :y
Kate
Quote from: MV6Gaz on 05 May 2015, 20:31:40
I'm going to connect it tomorrow.
The Sheriff
Quote from: Kate on 05 May 2015, 21:19:26
Don't forget to wet your middle finger and touch both wires before connecting them up, Kate, just to make sure there's power like. :y
Is this wise? :D ;D
A woman should be kept well away from electricity. :) :-* :-* :-* :-*
The Sheriff
Quote from: Doctor Opti on 05 May 2015, 21:25:11
Is this wise? :D ;D
Kate is a northern lass. She bends six inch nails between the cheeks of her arse whilst drinking nuclear brown and watching byker grove. ;D
Kate
Quote from: STMO on 05 May 2015, 21:27:59
Is this wise? :D ;D
Very accurate. ;D
Kate
Quote from: STMO on 05 May 2015, 21:21:34
Thanks for the tip. :y
