Senator back fire
Started by hoofing it, 08 May 2015, 22:01:56
hoofing it
Right all ive been having a wee problem with my Senny backfiring into the inlet manifold.
The timing is spot on all the leads,coil,plugs etc replaced but it stills does it.
Its a 1986 3.0 cdi
Im thinking along the lines of the valves and valve seats could be burnt out.
It came out of the factory as a unleaded (2 star) engine.
Any suggestions  :-\ :-\
4x4
Check for play on distributor arm,also rotor arm,and check dizzy cap,also efi ecu may be faulty.
Timing chain slipped?
Leaking injector?
4x4
Iirc there was a plug you could swap around to use either unleaded or 4* on the passenger side near shock mount.
biggriffin
Check leads in correct order on dizzy, check dizzy as they do wear out,there is a known fault with those distributor's.
I would post the fault on abs,as might be a member who can help.
Hoof'land storeman.
biggriffin
Quote from: 4x4 on 08 May 2015, 22:22:39
The ron plug. Thought it was on drivers side, green coloured,with 95' stamped in white letters,and you just un plug it and turned it over...
Hoof'land storeman.
4x4
Been a while since ive been under the bonnet of a senator,that was 15 yrs ago lol
Pretty sure my 89 Senator 12 valve didn't have the 'ron plug'  :-\
If you think burnt out valves, how about a compression test?
I'd doubt timing chain issues, having a duplex chain, they're usually bullet proof
It's been a very loooong time since I've been under the bonnet of a 12v Senny too
hoofing it
Cheers for the replies guys.
I never thought about the Dizzy being worn/loose.
All the leads are bosch and the plugs NGK.
I would ask on ABS (been a member for 10 years) but I can't remember my password or user i.d lol.
This engine doesn't have the ron plug and as ive found out getting parts is a pain in the arse because the 1986 senny A was made up with parts from GM/OPEL & VAUXHAL.
The car goes great it's more so noticeable when moving of from a standing start.
I replace the fuel pump.
The next step will be a compression test  :y
chuftsmv6
Hi there i love the senator I havnt seen one for years I really hope you get it sorted :y
Quote from: chuftsmv6 on 09 May 2015, 19:32:12
Hi there i love the senator I havnt seen one for years  ....
Me neither, though my daughter sent me a picture of a civvy L reg Senator she was sat behind at the traffic lights a few weeks ago
Webby the Bear
Whats the symptoms of a back fire? presumably loud bangs coming from tut inlet manifold? ive never heard of this before your thread :-[
RIP Paul Lovejoy
Lean running can cause backfiring too. :y
Rods2
Inlet or exhaust air leak?
hoofing it
Quote from: Webby the Bear on 09 May 2015, 20:31:15
It back fires on the inlet side (in the manifold)
The one I have is the A series (carlton shape) :y
