Author Topic: Omega 2.6 2002 auto air con problem  (Read 4318 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 13 May 2015, 09:46:38 »
Just purchased the car and the air con was not working. I read some where that if the air con has lost all its gas that the compressor won't run at all. Is this correct?
Thanks
« Last Edit: 13 May 2015, 09:56:29 by Andy A »
LC0112G
Re: Omega 2.6 2002 auto air con problem
« Reply #1 on: 13 May 2015, 10:32:13 »
Thanks
Yes - there are low and high pressure switches in the electrics which prevent the compressor running if the gas pressure in the system is too low or high.
Andy A
  • Bristol UK
« Reply #2 on: 13 May 2015, 10:42:59 »
The car is off the road for the foreseeable future. Is there an easy way to test if the compressor is dead or the gas is low or empty?
Would this bring a fault code up?
« Last Edit: 13 May 2015, 10:45:30 by Andy A »
LC0112G
« Reply #3 on: 13 May 2015, 11:44:41 »
Define easy. :)
One (illegal and potentially dangerous) way to tell if there is any gas in the system is to remove the cap on the A/C filler point and poke a suitable pointy thing into the hole. There is a tyre valve type Schrader valve in the bottom of the hole. If you hear a hiss of gas escaping then there is gas pressure in the system.
Odds are it's the A/C radiator (condenser) that has sprung a leak and there is no gas in the system. Typically costs £100-150 to DIY replace the rad (complete with the drier) and another £50 ish for a re-gas at a local place.
No.
Andy A
  • Bristol UK
« Reply #4 on: 13 May 2015, 14:29:52 »
Define easy. :)
No.
Is that cost for new parts and is it for generic or VX parts?
I was also told that the seals will probably need replacing due to being left so long.
Do you know what seals might need replacing and if it includes the two on the back of the condenser, can these be replaced with condenser left in situ?
LC0112G
« Reply #5 on: 13 May 2015, 14:44:32 »
Aftermarket pattern parts:
http://www.autoairconparts.co.uk/car-air-conditioning-condenser-aircon-radiator-vauxhall-omega-b-3-0-v6-petrol-manual-automatic-apr-1994-to-2013-part-16-6554.html
Check it's the right part for your engine/transmission combination though.
A new condenser comes with new seals, and yes they can be replaced with the condenser in place. But it's not likely to be just the seals, and I wouldn't just go round replacing seals willy nilly without some evidence that they are faulty. Some - including those on the back of the compressor - are a git to get at.
You shouldn't really do it - but I used compressed air to pump up my system, and I could hear the hiss of gas escaping from the rad, so that confirmed it. Threw a new condenser at it, put some clean pao oil in, and went for a re-gas.
Andy A
  • Bristol UK
« Reply #6 on: 13 May 2015, 14:58:47 »
Can these be done with the compressor left on the car or is it a compressor out job to get to them?
What is a safe psi to put into the system to test?
How much pao oi did you use and is it really necessary I thought I read some where that the gas already had oil in it?
« Last Edit: 13 May 2015, 15:02:27 by Andy A »
LC0112G
« Reply #7 on: 13 May 2015, 15:16:29 »
I'd say yes it can be done in car, but access to the back/top of the compressor is obstructed by all manner of gubbins, and access is difficult. The pipes come from the front, under the compressor, up the back of it and then bolt to the top of it. To disconnect you have to get a torx in on a long extension from the top of the engine bay past all the wiring, air and water pipes.
Unless you can feel/see oil on the compressors rear/underneath, I'd leave it alone.
There is no safe pressure. Compressed air and R134a gas are supposedly explosive when mixed under some conditions. Your car, your rules, but don't come crying to me if it goes boom.
That said, IIRC the low pressure switch cuts out at about 2 bar/30psi, and the high pressure switch at 8 bar/120psi.
I can't remember the exact numbers, but from memory, when new you're supposed to put roughly equal quantities (250ml?) of oil in the compressor, evaporator and condenser. I've never trusted the A/C places over the oil/gas mix, so prefer to do it myself. I'm not a qualified A/C tech though - even though I have got all the gear 8)
« Reply #8 on: 13 May 2015, 15:37:21 »
The aircon charge volumes/specs should be on a sticker on the slam panel ;)
Andy A
  • Bristol UK
« Reply #9 on: 13 May 2015, 15:43:15 »
Cheers Al.  :y
One last question. Where under the bonnet is the Schrader valve?
LC0112G
« Reply #10 on: 13 May 2015, 15:50:21 »
Andy A
  • Bristol UK
« Reply #11 on: 13 May 2015, 16:05:45 »
Thanks LC0112G for all your help and advice.  :y
All noted about the danger of mixing compressed air and R134a gas.
Thanks again
