Author Topic: abs ecu, will it fit?  (Read 6960 times)
Andy89
  • Norway
    • 97 3.0 MV6
« on: 14 May 2015, 09:36:40 »
My abs ecu is broken and needs replacing Bosch "0 265 203 004"
Can get easy hold of a Bosch "0 265 203 002"
Does anyone know if it can fit?
Diamond Black Geezer
    • & a silly coupe coming...
Re: abs ecu, will it fit?
« Reply #1 on: 14 May 2015, 09:44:35 »
As far as I'm aware the part number isn't the specific issue, you need to find the correct two letter code, be it 'BX' or whatever, and most crucially, what vehicle did it come off? Because it's a 'brain' it knows what vehicle it's from. Handily, the only info it 'knows' is engine and gearbox.
ie: 1997 2.5 V6 manual saloon in green ECU will fit a 2000 2.5 V6 manual estate in silver. Engine and 'box are only bits you need worry about.
wheras two silver Omegas, both saloons, both 2002 reg, both Elite, both got leather, registered on the same day, but one's a TD and one's a V6 it's a no-go.
Had this on a friend's car once and you will probably find you get lucky and get one reasonably quickly. There's not too many engines on the Omega, and most are Autos etc..
Just to add another important bit, you need to get one off a car with the 'correct' TC. If memory serves pre '97 cars are single channel Traction control, post '97 it's dual channel. So probably any pre-97 ECU is no good to you. Is your car definitely a mini-facelift? (Soft touch buttons, clear headlamps, lighter interior colour schemes, etc)
« Last Edit: 14 May 2015, 09:48:00 by Diamond Black Geezer »
« Reply #2 on: 14 May 2015, 09:49:57 »
Oh, and to add another bit... of course another ECU can be programmed to work in your car, but it's a potentially expensive trip to the dealer to have this done, which most of us avoid.
Sorry this is starting to sound more complicated than it needs to be. Look out for a 97-99 3.0 omega with whatever gearbox your car has and you'll be fine.  :)
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #3 on: 14 May 2015, 09:50:48 »
The two letter code  (on the yellow sticker) is XJ on mine and XD on the one I can get a hold of
My car is a 97 mv6 with original automatic, but I have transfered it to manual
The car the other one comes from is a 94 mv6 (guessing automatic)
Finding one from a manual car over here is nearly impossible i would say
« Last Edit: 14 May 2015, 09:53:48 by Andy89 »
« Reply #4 on: 14 May 2015, 10:26:50 »
In that case as per my previous post I think that ECU won't work, you need a 97-99 one, they changed the ABS from three to four channel in 1997. To be honest although you've found a 94 car ABS ECU, I'd have thought a 97-99 car would be far easier to locate, there just doesn't seem to be very many early cars left out there.
Have you posted in the Wanted section? I would hope that someone here would have a MFL 3.0 V6 ABS ECU, after all most people on here own the V6s.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #5 on: 14 May 2015, 10:43:54 »
My ecu and the one I am looking at are both 3 channel (they at least look identical on photos)
That change was made late 97 I believe (my car is pre face, not mfl)
the wanted section on here won't get me the item fast enough (and I cant post there yet, can i?)
The one I've got
The one i can get
« Last Edit: 14 May 2015, 10:50:46 by Andy89 »
« Reply #6 on: 14 May 2015, 11:01:51 »
A friendly admin may well have moved a wanted ad to the Wanted section, given that you're clearly in need. I think the post number requirements for selling/buying are to scammers putting up a single post 'for sale - my Omega' then taking someone's money then never giving them the car, kind of thing.
As far as I can tell that ECU looks fine, then. As you say late '97, was the ABS change, but of course being a changeover year you have to be careful. Of course cars can sit around many months before being registered, so you can't always guarantee these things.
I'd aim to get a second opinion from another OOFer or two, just to be on the safe side.  :y
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #7 on: 14 May 2015, 14:02:54 »
I have just bought it, cost me about 25£ so no biggie
It was from a manual car
fitting it tomorrow I guess, wonder if I can just change the ECU?
« Reply #8 on: 14 May 2015, 15:58:03 »
I've never known of anyone changing just the ECU part, actually. But as you say, 25 euro, so give it a try. Best of luck!
tidla
  • solihull
« Reply #9 on: 14 May 2015, 17:00:35 »
leave the hydraulics in situ as in the guides.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #10 on: 14 May 2015, 21:15:06 »
ain't no guides for the old system here
But I will just try fitting the ecu, then the entire unit if it doesn't work
« Reply #11 on: 15 May 2015, 09:01:13 »
Go for just the ECU part, then. Never followed a guide when I did it and we just dropped it in, without any bleeding of the system or anything, and worked fine. Could well be that we were lucky. Go as per the OOF guide, for sure.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #12 on: 16 May 2015, 10:02:34 »
I have changed the ECU now, the fault remains
The only difference is, now the abs light goes out when I start the car, but comes back on when I start driving (TC light is constant as before)
Before it was on constant
« Last Edit: 16 May 2015, 10:04:33 by Andy89 »
« Reply #13 on: 16 May 2015, 10:24:04 »
Sorry to be late to this, but a pre 1998 ECU cannot be used on a post 1998 ECU, as pre 98 Omegas had 3 channel ABS (with the rears combined), post 98 had 4 channel (fully independent).  Additionally, v6 ones are different to non V6 due to the TC functions.
The ident code is the important bit (DX for post 98 V6's normally), the config code can be entered via tech2 is required to match engine/drivetrain configuration.
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #14 on: 16 May 2015, 18:00:02 »
Should I try to replace the entire unit?
Page created in 0.022 seconds with 20 queries.
