2.5v6 cylinder heads needing new guides, stem sealsand valves...
Started by Webby the Bear, 31 May 2015, 16:46:45
Webby the Bear
..as above, I have these two sitting in the garage from the piston-valve meet a couple of years back. is it worth fitting new guides, seals and valves or will that be silly expensive?
if so is scrapping an option? Are they worth anything? or shall I just launch them down the tip?
tIA
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 31 May 2015, 16:46:45
tIA
Probably the easiest way ::)
other rides
Webby the Bear
Thanks mate. before I do ill have a word with the head mechanic and see if he can get me a deal at Cylinder Head Services for the guides/stem seals.....then I may consider getting new valves. but its looking like it will probably go to the scrappie :(
I just had a good old fashioned clear out of parts in the garage. most useless (not sure why I hoarded lots  ::)) but I did find some 2.5 cams.....as they are not in order whats the way to tell which ones 1,2,3 and 4?
RIP Paul Lovejoy
E cam is exhaust
F cam is inlet
Stamped on the front of the cams :y
tIA
Ally was getting on for £1 per kilo last time weighed scrap ally rims in. You'd have to remove guides, seats etc though  ;)
Gaffers
If you have a spare lump and want to learn hands on about all that gubins, I can think of no better way than that :y
My first ever mechanical job was a HG replacement on a 405 wheezle armed with a box of second hand tools and a haynes manual.  I learnt so much from just going through each phase.  I had to fabricate a tool for the timing belt (still have it somewhere) and borrow a torque wrench but got there in the end.
If I had the room I would love to do something like that :y
Webby the Bear
Quote from: JamesV6CDX on 01 June 2015, 08:12:30
E cam is exhaust
F cam is inlet
Sweet thanks james. I presume then that inlet cams are interchangeable as are exhaust cams?
RIP Paul Lovejoy
Webby the Bear
Quote from: Andy B on 01 June 2015, 08:39:41
tIA
Thanks Andy. What sorta weight are the heads?
RIP Paul Lovejoy
Webby the Bear
Quote from: Monsieur Guffer on 01 June 2015, 17:08:45
Yes mate got a spare 3l lump in the garage. Going to work on it when I get a chance  :y
RIP Paul Lovejoy
Webby the Bear
RIP Paul Lovejoy
