Author Topic: Impact gun ?  (Read 2906 times)
EMD
  • Noofhampton
    • 95t
Impact gun ?
« on: 16 June 2015, 22:14:53 »
Any good ? Will it undo wheel nuts  :-\
Linky
Omegatitis
Re: Impact gun ?
« Reply #1 on: 16 June 2015, 22:25:31 »
My Clarke badged Chinese one is claimed 450Nm, but will struggle with wheelbolts that haven't been touched for a few weeks, or that have ben done up with windy guns.
So a cheap Chinese tat one claiming 300Nm?
You can take my answer as "unlikely"
EMD
  • Noofhampton
    • 95t
Re: Impact gun ?
« Reply #2 on: 16 June 2015, 22:31:08 »
Any idea what the highest Nm is available at a reasonable price and what features to look for , its mainly for wheel bolt removal and maybe the odd exhaust clamp .
Omegatitis
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Impact gun ?
« Reply #3 on: 16 June 2015, 22:32:22 »
I'd agree with that, and would question the quality/power/durability of the batteries too.
Re: Impact gun ?
« Reply #4 on: 16 June 2015, 22:36:50 »
My DeWalt claims 200Nm, but is more powerful than my Clarke claiming 450Nm.
I think, to be blunt, avoid the cheap, unbranded (or rebadged Chinese like Clarke, Sealey etc) tat
  • Chatham, Kent
Re: Impact gun ?
« Reply #5 on: 16 June 2015, 22:39:29 »
Do you already have any cordless tools? If so check that range has an impact wrench available. For instance, the Ryobi One+ will loosen correctly tightened wheel nuts(even though it claims over 200Nm) and there are loads of other tools, like an angle grinder which is probably better for exhaust clamps.
The real use of the lower capacity impact wrenches is not to loosen tight bolts, but more for time saving moving large bolts as found in suspensions etc.
A long, flex-head 1/2" drive ratchet like Sealey's AK6698 is MUCH better value than a cheapo cordless impact wrench
Re: Impact gun ?
« Reply #6 on: 16 June 2015, 22:41:50 »
I have a rather strange impact gun, works well enough, switch it on and it spins like mad and then suddenly locks, with quite a bang, and hey presto, nut undone.......... :y :y
Re: Impact gun ?
« Reply #7 on: 17 June 2015, 00:55:58 »
This is cheap enough and should undo your stubborn wheel nuts.  :y
Linky
Re: Impact gun ?
« Reply #8 on: 17 June 2015, 01:41:45 »
Linky
Whats wrong with a scaffold bar? worked in my youth, on busses.......... :y :y
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Impact gun ?
« Reply #9 on: 17 June 2015, 08:38:03 »
The cheaper ones are ideal as a time saver, I tore the front end off a breaker in about two hours, wheel nuts one cracked are plenty doable and to be fair they should be torqued up by hand anyway.
Re: Impact gun ?
« Reply #10 on: 17 June 2015, 10:08:45 »
Just to check - is that will or will not (because 'will' seems contrary to 'even though it..')?  I'd been looking at the One+ stuff to replace some of the Wickes cordless tools I've got; because Wickes stopped making them after I'd bought two of the whole set  ::) (Note to self: Buy them all at once next time!)
  • Chatham, Kent
Re: Impact gun ?
« Reply #11 on: 17 June 2015, 10:17:13 »
Aaron, that should have read "will just loosen correctly tightened wheel nuts". It's a decent tool, as are most of the rest of the range. B&Q often have the drill with 2batteries for about £100 which is a good start, the anglegrinder is really handy for little jobs, and the vac is good for quick mini-valets. I bought the circular saw, angle drill, lamp and a bunch of batteries for £40 a few months ago but can't comment on their effectiveness.
The 4amp battery makes a big improvement, especially to the grinder.
Re: Impact gun ?
« Reply #12 on: 17 June 2015, 10:21:44 »
Gotcha - thanks Nick  :y
The angle grinder was what attracted me in the first instance, windy gun could be handy (I have the big air gun for wheel bolts etc anyway) and my Wickes circular saw is a bit lacking in oomph.  Angle drill always handy, too..
Might invest next month then, thanks!
