Author Topic: NCD1013 reset  (Read 8840 times)
Re: NCD1013 reset
« Reply #15 on: 30 June 2015, 20:37:33 »
happy to plug in the code reader that shall not be named if it helps...No idea what its likely to display for it though.
If you do, grab the code index off it. Should be 074 for a 3.2
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
Re: NCD1013 reset
« Reply #16 on: 30 June 2015, 20:47:11 »
Had finger on button longer than that. James.... I may take you up on the offer
 I'll be in touch.
    • E250 Est / Elroq
Re: NCD1013 reset
« Reply #17 on: 30 June 2015, 20:54:53 »
No worries.
Not saying I can do anything, but may be able to get some handy diags.
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #18 on: 30 June 2015, 21:00:49 »
Cheers James  :y
    • E250 Est / Elroq
Re: NCD1013 reset
« Reply #19 on: 02 July 2015, 12:32:16 »
I Had a look at this one last night.
First of all, none of the press and hold's had any effect at all?
Problem looks to be GID not seeing a crank signal?  Altough instant tank content looks variable?
Live Data on a short run
http://images.omegaowners.com/images/Jimbob/hosted_for_others/KLD.csv
Fault codes
http://images.omegaowners.com/images/Jimbob/hosted_for_others/KFC.txt
GID Data
http://images.omegaowners.com/images/Jimbob/hosted_for_others/KGID.csv
Menu system showed english units selected, but diag tool suggests Japenese?
No other codes in the car, was running fine, maybe benefit from a breather / TB / ICV clean as the idle could have been smoother.
Ive no access to anything else with a GID to compare findings.
Thoughts?
Re: NCD1013 reset
« Reply #20 on: 02 July 2015, 17:16:30 »
As stated earlier, I don't think its getting the injection duration signal
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #21 on: 02 July 2015, 19:20:50 »
So what's needed to get this do we know?
    • E250 Est / Elroq
Re: NCD1013 reset
« Reply #22 on: 05 July 2015, 12:42:42 »
Can anyone help with a where to look idea?
Re: NCD1013 reset
« Reply #23 on: 05 July 2015, 15:58:31 »
check wiring diags, check connectivity on wire(s) between display and engine ecu.
if ok, suspect display.  did you get code index off it?
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #24 on: 06 July 2015, 08:58:24 »
I changed a couple of bulbs behind this display for the bloke that used to own it several months before I bought it... Are we saying there could be a loose connection at the back..
