Author Topic: NCD1013 reset  (Read 8827 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
NCD1013 reset
« on: 30 June 2015, 14:17:14 »
Some of the options I.e consumption will not reset along with a couple of others.. Some work fine like the " range"  the consumption one when attempting to reset starts with ( ----) as a display then goes to 99.9 mls .It stays on this regardless of how long vehicle driven... What's needed to fix this guys?
Re: NCD1013 reset
« Reply #1 on: 30 June 2015, 18:32:15 »
S'nout to do with the NCDC, that plays no part in the Board Computer other than as an input device.
Which functions work? Is the Range value feasible?  You are looking for the single thing that impacts the duff readings.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: NCD1013 reset
« Reply #2 on: 30 June 2015, 18:33:03 »
Main and clear for 6 seconds iirc...?
Worth a search it's on here somewhere, if you want to dis-count it.
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #3 on: 30 June 2015, 18:38:14 »
Working info is...range  , speed and trip distance...
Not working is...trip consumption, consumption, or inst consumption
Re: NCD1013 reset
« Reply #4 on: 30 June 2015, 18:39:04 »
Just CLEAR for 6s (until screen blanks briefly), but that resets the NCDC, not the GID/CID
Re: NCD1013 reset
« Reply #5 on: 30 June 2015, 18:39:39 »
Is the Range value viable?
As looks like its pointing towards not seeing the injection duration values.
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #6 on: 30 June 2015, 18:43:56 »
Speak English  :D
Re: NCD1013 reset
« Reply #7 on: 30 June 2015, 18:45:05 »
Speak English  :D
IS
THE
RANGE
VALUE
DISPLAYED
ABOUT
RIGHT
FOR
THE
AMOUNT
OF
FUEL
ON
THE
FUEL
GAUGE
:P
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #8 on: 30 June 2015, 18:46:47 »
Haha yes mate it seems about right
Re: NCD1013 reset
« Reply #9 on: 30 June 2015, 18:55:20 »
When did this start?  Has the Range value changed since it happened?
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #10 on: 30 June 2015, 19:01:28 »
Only had car a month and thought id try it today but computer says no.
Re: NCD1013 reset
« Reply #11 on: 30 June 2015, 19:26:41 »
OK, after you have next driven it, see if the Range changes.
In the meantime, press and hold MAIN for 6s, then press BC, then post up everything that's on the screen.
    • E250 Est / Elroq
Re: NCD1013 reset
« Reply #12 on: 30 June 2015, 19:55:38 »
happy to plug in the code reader that shall not be named if it helps...No idea what its likely to display for it though.
vauxsull
    • 3.0 Elite
Re: NCD1013 reset
« Reply #13 on: 30 June 2015, 20:32:41 »
Pressed main for 6 seconds  then bc.... No change to display.
Re: NCD1013 reset
« Reply #14 on: 30 June 2015, 20:37:02 »
Maybe you count too fast ;D, try 8s ;D
