inner tyre wear.
Started by Dan282, 16 July 2015, 19:53:02
Dan282
Only noticed the other day I had some pretty bad inner wear on my OSF tyre. Odd really as I couldn't feel anything except a tiny steering wheel wobble at high speed.
New tyre now fitted and tracking done but a very good tyre ruined.
[/URL[URL=http://s81.photobucket.com/user/puma282/media/Mobile%20Uploads/IMAG0750_zpsagdlkqyj.jpg.html]
Identify the broken bit, replace and get it set up properly otherwise the new tyre will do exactly the same thing ::)
X30XE
The new one will go very much the same way unless you replace the defective suspension bush that's causing the issue. Tracking will do sod all  :y
Omegatitis : [in remission]
Dan282
It's going in for its mot on the 4th August so I will ensure it gets checked out.
chrisgixer
Yep, and it will likely ruin another one due to excess CAMBER. ....NOT tracking. Excess cam per can be due to a failed bush or bad adjustment after suspension work
At very least get camber checked o full get set up rig, such as hunter hawk eye. Fleet fit  Loughborough nearer than wheelsinmotion.co.uk for you are they?
http://www.loughboroughtyrescentre.co.uk/TyreInfo/GuideToAlignment
Dan282
Cheers Chris I will look in to that. I thankfully do a low mileage so shouldn't incure too much wear.
Quote from: Dan282 on 16 July 2015, 20:04:04
Cheers Chris I will look in to that. I thankfully do a very low mileage so shouldn't incure too much ware.
A thousand miles is enough to completely destroy a tyre with a poor set up...
chrisgixer
#7
Also see this guide. Set up cost money, so to make the most of it, it's worth checking the rest of the components first. No point paying for set up then finding it needs parts for the mot or to rectify the underlining cause, that need set up again.
As explained here
http://www.omegaowners.com/forum/index.php?topic=90492.0
Dan282
#8
I refuse to drive on that tyre. At most I will do a few hundred miles between when I have it done.
Chris. Yes I will make sure any components are replaced prior to any set up being done buddy.
Cheers :) :y
chrisgixer
Quote from: chrisgixer on 16 July 2015, 20:01:51
Think that's the place master uses?
Can somebody confirm?
Dan282
Quote from: chrisgixer on 16 July 2015, 20:07:17
As explained here
Just had a good read! Great guide 👍👍
Broomies Mate
Looking at how that weight has been positioned, I wouldn't trust the fitter to do up their own shoe laces.  >:(
DrAndyB
Nice tailpipe  :y
Slightly off topic, but is exhaust full stainless ?
