Author Topic: Fault code P1781 & P1740 ??? On 2.2 FL Petrol Auto ???  (Read 2688 times)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Got these from the Pending Fault codes.
Cant seemed to find them on the list ?
Car starts a great now with clean throttle body  :y
I have reset the codes and there were no other codes logged.
Not sure what they are.
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: Fault code P1781 & P1740 ??? On 2.2 FL Petrol Auto ???
« Reply #1 on: 18 July 2015, 16:44:38 »
From my Autel
P1781 - ECM actual torque signal - malfunction detected
P1740 - AT torque control. signal malfunction
Looks like something to do with gearbox, Pending codes tend to clear with ign off/on
I'd Wait to see if they come back then do something, cam sensor is used by AT ecu
    • E250 Est / Elroq
« Reply #2 on: 18 July 2015, 21:13:51 »
Memory tells me the Cam sensor on a 2.2 can give bizarre false autobox codes.
DrAndyB
« Reply #3 on: 19 July 2015, 00:09:42 »
Thanks for advice and hints.
Have reset all and oil now changed to propper vx 10W/40 Semi.
Old black stuff which i drained seemed very "thin" but they had put 5W 30 full synth in !!!
I am happy now she has genuine GM oil and cleaning throttle body as per OOF guide has cured idle gremlin a treat  :y
Will check for codes in morning as all reset and gave he a run today.  Fingers crossed.
