MOT today
Started by vauxsull, 04 August 2015, 12:06:40
Page 122 of user manual, from memory (as my manual is 2000 miles away)
vauxsull
Mine is 17 miles away.. Could someone post an image of that page up on here??
The whole manual is on here in PDF format  :y
vauxsull
How would I access that on mobile?
Quote from: vauxsull on 05 August 2015, 09:58:52
go to "Omega common issues and FAQ" then index to section and use 'find on this page'
http://www.omegaowners.com/forum/index.php?topic=90477.0
vauxsull
Obviously this doesn't apply to HID headlights as no such lever exists behind mine?
Quote from: vauxsull on 06 August 2015, 12:58:44
HIDs most definitely DO have the lever  :y
vauxsull
Lever was found and adjusted and all went well on MOT retest...however the broken spring  he said I needed and quoted me £128 to supply and fit 2 turned out to be b*****s as I bought a pair of KYB's and fitted them myself only to discover the ones I was taking off where perfect... Apologies all round and a refund of the money I spent on Springs.... Just goes to show I could be well out of pocket for something I didn't need.
Depo lights do have the lever, but it's accessed through the other opening and works slightly differently ;)
Where did you take it for a test Keith?
vauxsull
Wrexham motor tech Pete.
Quote from: vauxsull on 07 August 2015, 18:04:40
Lever was found and adjusted and all went well on MOT retest... ...
I've often presented my car for MOT with the headlights set to driving on the right ..... can't see a problem as long as they're both set the same.
vauxsull
The MOT tester wanted to quote me for a new headlamp
EMD
So they were trying to make a few bob out of nothing , shame on them :(
Omegatitis
