Ok, I can officially put this 0-60 'dangle berries' to rest
Started by Webby the Bear, 04 August 2015, 18:07:33
Quote from: Harris K Telemacher on 14 October 2015, 08:04:19
Here we go then...
'54 Manual Plod 3.2 Estate, 272500 miles, original engine/box/diff, IRS calibrated speedo, level road, 3.0° C, 5/8 fuel, 110kg driver and a 49" Whelen Liberty lightbar on the roof...
This is how you do it Webby
0-60mph in 7 seconds :P
Pop that in your pipe and smoke it Mr Dbug :D
Was that going down a steep hill?  ;D
The acceleration is constant, even through the gear change.  :-\
henryd
Quote from: STEMO on 14 October 2015, 12:15:55
Here we go then...
Nah,back end up on stands :D :D ;)
other rides
Gaffers
Quote from: henryd on 14 October 2015, 12:19:21
Here we go then...
Last time I saw Al's miggy do that kind of acceleration it was after a curry.  Coincidence?  I think not ;D
Here we go then...
That's called momentum ;)
If anything, it's up a very slight incline... was southbound on the A24 between Great Daux roundabout and Robin Hood roundabout starting from the layby on that stretch...
Quote from: Monsieur Guffer on 14 October 2015, 10:03:42
Here we go then...
Still slower to 30 than a milk float :)
Minimum range: 240 miles :-X
Here we go then...
Perhaps I was a tad pessimistic in my 8-9 secs, although unsure if your ex plod is representitive of a normal non plod car.  However your original statement was also a tad optimistic - "a two ton saloon capable of hitting 60 in 6-7 seconds" - looking at your video I concede it reached 60mph on your speedo (when was it last calibrated?) between 7 and 8 secs.
Quote from: dbug on 14 October 2015, 16:06:46
Here we go then...
Opps me you're nitpicky... Speedo calibrated by IRS on install.. Current tyres are the same rolling radius as the factory supplied originals. Video equipment is calibrated much more regularly as it is evidential.
If I wanted to make excuses I could blame the time on the tyres being at their limit (being replaced tomorrow), the practicalities of filming from a breast pocket and of course the 4' 12"x1" plank bolted across the roof screwing up the airflow...
As for plod not being a production representation, a manual 3.0MV6 estate should be broadly similar.
Purpose was to demonstrate that the 3.2 has more potential that naysayers like you care to admit. :-X
Webby the Bear
Seeing as though every oof member has nit picked at my practises  ;D your video STARTS when you're doing 10mph!  ;D ;D ;D
RIP Paul Lovejoy
Webby the Bear
Actually just re watched it and it's about at 0mph on the gauge to be fair. Though I was told on this thread that's not when to start! You start the moment you touch the accelerator.
More work needed  ;D
RIP Paul Lovejoy
Webby the Bear
Anyways re my speed tests. Got my vacuum gauge in the post today. Will be looking for exhaust restrictions and vacuum figures tomorrow.
Anyone know what the figure should be at idle for the omega?
RIP Paul Lovejoy
Quote from: Harris K Telemacher on 14 October 2015, 19:28:10
Here we go then...
Pot kettle black ;D ;D must be contagious  ;D ;D
Calibrated back in 2003/4 - take it its still "calibrated" as you used it in your video ???
Agreed, but you don't have the video equipment ;)
And should perform eactly the same as its broadly similar. ;D
Just being "nitpicky"  ;D ;D ;D
It's accurate enough ;) As for video, once the VASCAR is fully installed we can put it to the test...
As for the 3.0 comparison, it's the closest retail model, so the broadly similar reference allows for the subtle differences in the way the engines deliver their power.
Wasn't done as a scientific test anyways, merely to demonstrate a point... ::)
Quote from: Webby the Bear on 14 October 2015, 23:21:13
More work needed  ;D
Had the camera set on a ten second delay... Hammer went down as it beeped when it started recording :y
Webby the Bear
Quote from: Harris K Telemacher on 15 October 2015, 04:48:26
More work needed  ;D
And I trust you had the extra 200kg in weight in the car that Vauxhall used when they tested the motor, you know, for a true comparison ?
RIP Paul Lovejoy
