Ok, I can officially put this 0-60 'dangle berries' to rest
Started by Webby the Bear, 04 August 2015, 18:07:33
Webby the Bear
RIP Paul Lovejoy
Broomies Mate
Quote from: Webby the Bear on 26 October 2015, 22:51:52
Quote from: Webby the Bear on 26 October 2015, 12:24:19
The possible wear in the tranny could cause acceleration loss?
Anyone confirm this?
Yes it can if the gear changes are sluggish due to loss of friction.  Think of it as a slipping clutch on a Manual.  Not all of the intended 'power' is being sent to the driving wheels.
But how far do you go?  If the Diff oil is not at it's prime, it'll cause extra friction in the Diff, causing a loss of power to the driven wheels.
etc etc etc etc etc
Diamond Black Geezer
Has Mr The Bear not done his gearbox oil? Certainly worth doing it if you haven't, even for preventative maintenance. I found just over a litre more went in, than came out of mine  :)
I can't think of anything in the transmission which could absorb a significant amount of engine output yet not destroy itself in the process. Certainly, if it was slipping, it would burn out the clutches in short order.
By all means do a fluid change, as that's advisable on a regular basis anyway, but don't count on it making much difference. ;)
Not being intricately aware of the workings of a torque converter, would this be the logical place for any slip to occur?
Personally I think Webby's got a damn fine engine, myself. Any engine that can produce 99% (and possibly 100%, we'll never know unless it was bench tested the day it left Russelsheim) of the same power so many years after being built is brilliant.
BazaJT
The saga continues!!This is set to run longer than Coronation Street :D ;D
Webby the Bear
Quote from: Broomies Mate on 26 October 2015, 22:58:08
etc etc etc etc etc
Perfect thanks broomie  :y
RIP Paul Lovejoy
Webby the Bear
Quote from: Kevin Wood on 27 October 2015, 11:10:10
Sorry kev, are you agreeing that the loss of performance could be in the gearbox?
To be totally honest, as long as I have a reason for where the power has gone I am not fussed about getting a new gearbox to fix five tenths at the race track! But as a new car mechanic I like to understand it and have a definitive reason for it.
The facts are these. . . I have proved my engine is performing exactly as it should and did all those years ago. . . It has to be the tranny.
How to test this for sure. . . Transmission oil analysis! And yes, I am that sad  :y
RIP Paul Lovejoy
Webby the Bear
Quote from: Diamond Black Geezer on 27 October 2015, 10:51:03
Lol no mate I've never changed it. And that's cos I read somewhere that if you do an oil change on an ageing tranny that's never had new oil, it can wreck it. Sum at to do with the new 'slippy' oil being able to bypass things that the old oil (being thicker) was sealing up. That's what I heard. No idea if that's true.
RIP Paul Lovejoy
Quote from: Diamond Black Geezer on 27 October 2015, 14:06:42
Have a read of this article https://en.wikipedia.org/wiki/Torque_converter
Quote from: Webby the Bear on 27 October 2015, 21:16:27
I changed the oil in mine about 20,000 miles ago (at 185,000 miles) because it is slow to engage reverse and I wanted to see if there were any things in the sump that shouldn't be there. It didn't make any difference at all. ::)
Broomies Mate
Different transmission admittedly, but my 126,000 mile Saab has been treated to THREE transmission oil changes in quick succession (30 miles between changes).  The Transmission fluid was dark, and didn't smell great.  Not a lot of fluid is in the sump, so a simple drain and re-fill won't replace a lot, three efforts, and there is still old fluid in there.
More difficult with the stupid 'sealed for life' crap in the Omega and lots of other modern cars.
Anyone who believes an Auto Transmission doesn't benefit from fresh oil needs a lesson in Oil degradation!   ::)
Noo, well worth an oil change, vauxhall themselves recommend it on higher mileage (because they never get servicing times wrong *cough timing belt cough timing belt*) :y
tigers_gonads
So what IS the 0-60 time supposed to be then ..............   ::)
I've forgotten what Webby's actual time was, now, it was that long ago  :D
Brochure is 9.5 or thereabouts?
