Author Topic: P1335 & P0725 relating to 2.2 DTi  (Read 1572 times)
Only Me
  • Sunny Hartlepool - no honestly it is sunny
    • Omega 2.2 DTi CDX
« on: 26 August 2015, 17:31:20 »
Hi de Hi campers,
Went to see a friend today and 5 mins into journey, my mig went into limp mode, reduced power etc and rev counter died, exactly as per
http://www.omegaowners.com/forum/index.php?topic=81429.msg1072791#msg1072791
Limped car home, got codes read at a local garage, they have ordered a crank sensor. Came home, read through threads and now slightly concerned that new crank sensor may not be the solution.
Mig was serviced in last few months and apart from going into limp mode when stationary (i.e idling) and throwing up P1635 and P0400 codes runs fine. EGR is clean (although if you read the forum threads EGR never causes P1636 or P0400 anyway) although mainfold is filthy.
Car runs very rough atm as if it isn't firing properly and quite alot of white smoke exitting exhaust.
Any help would be appreciated. I am aware that DTi's aren't that plentiful.
Regards
Neil
P.S Found this which seems to fit the bill in a previous thread, any thoughts
http://www.omegaowners.com/forum/index.php?topic=117252.0
« Last Edit: 26 August 2015, 17:40:18 by Only Me »
Only Me
    • Omega 2.2 DTi CDX
Re: P1335 & P0725 relating to 2.2 DTi
« Reply #1 on: 28 August 2015, 19:41:53 »
Update,
New crank sensor was fitted which hasn't solved the issue as thought above. Old sensor was fine despite thowing up crank code (need to double check resistance on old one to be sure).
Car taken for another spin and car went into limp mode again. This time threw up two new fault codes relating to MAF P0100 which was unplugged before test drive anyway, then car was started and MAF replugged in. MAF code was cleared and tested and found to be ok (just like the crank sensor so no need to replace that MAF part as just wasting money) and the second codes was P1125.
So down to checking vacuum pump reading at idle wrt servo as per
http://www.omegaowners.com/forum/index.php?topic=119275.0
as well as boost vacuum pressure sensor on the inlet manifold due to P1125 code
Rubber elbow at back of vac pump.
Don't want to get into situation like P6UL K where everything gets replaced and still fault persists
http://www.omegaowners.com/forum/index.php?topic=120326.0
On face value all codes relate to high or low voltage input or open circuits - P0100, P0400, P0725, P1125, P1335, P1635
http://www.omegaowners.com/forum/index.php?topic=90667.0
Regards
Neil
« Last Edit: 28 August 2015, 19:57:31 by Only Me »
