Author Topic: V6 Nasty Engine Noise  (Read 11640 times)
Re: V6 Nasty Engine Noise
« Reply #15 on: 21 September 2015, 12:25:34 »
I can't answer the question about under load, as I cannot hear the noise at all when driving :)
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #16 on: 21 September 2015, 13:42:36 »
Odd, as I thought I had similar issues as yourself, but mine's actually more audible under load and with revs... I'll be starting with an oil change and go from there. Will watch this thread with interest, and hope you get sorted very soon.  :y
If JamesV6CDX has an engine fault he's unsure of then none of us are safe!!!  :o
EMD
  • Noofhampton
    • 95t
« Reply #17 on: 21 September 2015, 16:21:35 »
You did use the T-vents from the original engine?
What are T-vents used for and where are they in the omega  ???
Omegatitis
« Reply #18 on: 21 September 2015, 22:01:08 »
Inside the cam/lifter area they channel oil away IIRC?
gringotty
  • merseyside
    • omega 2.5 estate
« Reply #19 on: 21 September 2015, 22:24:40 »
Hiya, do one little test for me, when the engine is running lift off the oil filler cap and tell me if it changes the level of noise.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #20 on: 21 September 2015, 23:35:08 »
i was going to suggest that but there seems to be no filler cap in the video....
« Reply #21 on: 22 September 2015, 00:45:47 »
It's there... Just fitted with without the filler neck and therefore obscured from the camera by the cable tray  :y
EMD
  • Noofhampton
    • 95t
« Reply #22 on: 22 September 2015, 17:31:48 »
That doesnt sound like lifter noise. Possibly bearing noise cam belt related , there has been a few duff cam belt kits around  :-\
Omegatitis
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #23 on: 22 September 2015, 19:56:24 »
Here's a daft question for you......are all your spark plugs tight enough?
I've seen it before albeit not on an Omega!
« Reply #24 on: 23 September 2015, 03:22:19 »
I'm open to all ideas guys :y
Oil has been draining since weekend... Will refill and do a video from cold tomorrow :y
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #25 on: 23 September 2015, 04:29:28 »
That engine was from the 120k MV6 estate and did not have that sound with the old 3.2 heads so I would say it is from the 3.0 heads you have added to the engine. I know you have done the job 100's of times but when you did cam covers were all the oil ways/drains clean :-\
omega2018
« Reply #26 on: 23 September 2015, 14:55:18 »
is it louder with the filler cap off (i.e. is the noise coming from the top end)?  difficult to tell but sound like belt related to me not valve.
« Reply #27 on: 24 September 2015, 15:25:08 »
Took the Cambelt kit off today.
All good. Idlers all run totally smooth.
I took the 246 rocker off. All looked good. I took the camshafts out.
It would appear some metal has broken off under the Inlet camshaft on the head.
Bugger it.
« Reply #28 on: 24 September 2015, 15:27:50 »
Metal has broken off? Sure it's not just a rough edge on the casting?
A picture would be handy. :y
« Reply #29 on: 24 September 2015, 15:33:20 »
I thought the same, and the fact there is no sign of any foreign object or filings would be consistent with a rough edge...
No explanation for the noise, though!
Pages: 1 [2] 3 4  All   Go Up
