Author Topic: Oil change time ??  (Read 3155 times)
Oil change time ??
« on: 18 October 2015, 21:32:50 »
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Oil change time ??
« Reply #1 on: 18 October 2015, 21:35:04 »
Ive seen this report, i still dont know what to make of it :(
flyer 0712
« Reply #2 on: 18 October 2015, 21:52:25 »
So does this cartridge put new oil in and takes old oil out......Surely if it does then it is similar to using a pump to suck out the oil before putting the new oil in by hand.....if so,,question is by taking oil out by pump it does not remove all of the sludge in the bottom of the sump,,,,,,where as removing sump plug will.....still its progress i suppose  :-\
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 18 October 2015, 22:23:55 »
Do you have to wear them glasses too  :-\
« Reply #4 on: 18 October 2015, 22:37:12 »
If the cost will be like printer ink, it will make those cartridges about £750  ;D
« Reply #5 on: 19 October 2015, 07:51:59 »
Wonder if a top up is possible if needed?
« Reply #6 on: 19 October 2015, 08:22:27 »
Which sludge is that? Sounds like same as the comments re using a vacuum pump on my Smart ...... and there's been no sludge in the sump on the couple of occasions I've removed it.
« Reply #7 on: 19 October 2015, 08:27:46 »
Trouble is that you are in the hands of the previous owner regarding sludge and missed oil changes.  :y
Get lucky and no issues, pick up an older motor with a chequered history and it is bad.
« Reply #8 on: 19 October 2015, 11:56:55 »
And what of the oil filter?
« Reply #9 on: 19 October 2015, 12:13:02 »
The logical answer would be to build it into the module along with the oil.
« Reply #10 on: 19 October 2015, 12:15:44 »
But, the analogy with the printer cartridge has been made... How long before these are "chipped" so that they can only be changed at a main stealer, you get a "demo" one that will only last for 1000 miles when you buy the  car new and the car won't go if you use a "pattern" part?
KSR
  • South west
    • Omega 2.5 TD & Corsa C
« Reply #11 on: 19 October 2015, 12:51:23 »
Can't see it kicking off.  dry sump vehicles maybe .... but nahh
  • Auckland
    • Mazda MPV
« Reply #12 on: 19 October 2015, 13:04:42 »
The other analogy concerns the cost of printer ink sold in a printer cartridge vs the cost of a bottle of ink :(
