Author Topic: quantas pilots  (Read 1327 times)
johnnycboy
  • Colchester
quantas pilots
« on: 15 July 2008, 18:31:56 »
It takes a uni degree to fly a plane but only an apprenticeship to fix one:  a reassurance for those of us who fly routinely in their jobs.
After every flight, Qantas pilots fill out a form, called a "gripe sheet" which tells mechanics about problems with the aircraft. The mechanics correct the problems;  document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humour. Here are some actual maintenance complaints submitted by Qantas' Pilots (marked with a P) and the Solutions Recorded (marked with an S) By Maintenance Engineers.
By the way, Qantas is the only major airline that has never had an accident.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel . Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget
mantahatch
Re: quantas pilots
« Reply #1 on: 15 July 2008, 18:42:01 »
Tis a great joke, but, Quantas have had an plane accident, one of there aircraft overshot the runway and ended up in field, fortunatly no deaths.
Also because Quantas has not killed anybody yet, I would not fly with them because they are well overdue a big incident.
Mike
haj
  • Brighton
Re: quantas pilots
« Reply #2 on: 15 July 2008, 20:34:02 »
Did you know that Quantas is an acronym of-queers and nymphamaniacs travel as stewards :o
Re: quantas pilots
« Reply #3 on: 15 July 2008, 20:35:13 »
very accurate  ;D ;D ;D
Re: quantas pilots
« Reply #4 on: 15 July 2008, 20:35:59 »
Those have been around the Quaint-Arse community for some while ... IIRC there used to be a link on Quantus web site to a whole load of similar stufff
johnnycboy
  • Colchester
Re: quantas pilots
« Reply #5 on: 15 July 2008, 20:38:47 »
entwood i apologise if i offend, its called a joke
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: quantas pilots
« Reply #6 on: 15 July 2008, 20:41:48 »
thats pretty much any airline!
Danny
  • Wigan, Greater Manchester
Re: quantas pilots
« Reply #7 on: 15 July 2008, 21:37:26 »
P: IFF inoperative.
S: Cat installed.
BLOODY funny!!! ;D
