Author Topic: Dead battery - can't get into Neutral  (Read 3906 times)
JohnK89
  • Middlesbrough
    • Omega's!
« on: 14 November 2015, 08:51:36 »
Hi all,
2002 Omega MV6 Auto
Battery is dead, bonnet cable has snapped which is a bugger as well. Cars on a neighbouring driveway but needs to be shifted.
I can't get it out of Park so that I can push it into the road for further investigation, which I believe is because the battery is dead and there's no power - is there a manual override to get into neutral so I can, at the very least, get the car moved?
John.
Re: Dead battery - can't get into Neutral
« Reply #1 on: 14 November 2015, 08:56:39 »
Yep... It's in the manual ;)
Pull the gear shifter surround up and there is a little yellow lever on the side of the stick at the bottom. Right hand side IIRC.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 14 November 2015, 09:42:56 »
Are you sure bonnet cable snapped. Sometimes getting a helper to push the front of the bonnet down and pulling the lever the bonnet will open.
Hoof'land storeman.
« Reply #3 on: 14 November 2015, 16:20:04 »
Seconded...
Failing that, Please read the manual :P
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #4 on: 14 November 2015, 20:00:48 »
What Please read the manual,or is it a technical term :)
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 14 November 2015, 20:05:08 »
IITYWIMWYBMAD
  • Online Online
« Reply #6 on: 14 November 2015, 20:26:56 »
http://lmgtfy.com/?q=Please read the manual  ;) ;) :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #7 on: 14 November 2015, 20:35:40 »
I'm not even going to try working that one out Zirk!Took me long enough to figure out what dilligaf meant ;D
« Reply #8 on: 14 November 2015, 20:37:43 »
Read The (insert word of choice beginning with 'F' here) Manual :D
Although I should add, in the name of pedantry; there's no 'f' in 'manual' ;D
Toledodude1973
  • IPSWICH U.K.
« Reply #9 on: 14 November 2015, 20:38:32 »
I knew it was technical term ;D ;D
zirk
  • Epping Forest
« Reply #10 on: 14 November 2015, 20:38:59 »
If I tell you what it means,
Will you buy me a drink.  ;)
« Reply #11 on: 14 November 2015, 20:40:53 »
OIYSP :y
« Reply #12 on: 15 November 2015, 11:36:18 »
OIYSP :y
¯\_(ツ)_/¯
« Reply #13 on: 15 November 2015, 14:27:28 »
Only If You Say Please ::)
No wonder the world is oppsed.
BazaJT
« Reply #14 on: 15 November 2015, 16:56:14 »
Please read the manual-I already knew this one.
OIYSP-I managed to work out
It's the longer one that Zirk posted that's got me,but then I'm not the sharpest knife in the drawer :D
