2.2dti life expectancy.
Started by The Red Baron, 08 December 2015, 20:17:18
The Red Baron
What sort of miles do these engines go to before becoming a problem.
Quote from: The Red Baron on 08 December 2015, 20:17:18
Depends how keen you are to change the oil regularly.
The engine itself isn't too problematic, but pump failure is common, and will write off the car.
Needs intake cleaning out regularly.
EMD
Ive seen a few make 300,000 + miles  :) There does seem to be an alarming number of older Vauxhall dti in general that have failed fuel pumps  :(
Omegatitis
amazonian
Yea, got one of those, 120k.  :(
Quote from: amazonian on 08 December 2015, 23:27:44
You know my thoughts on that :-X
JoeRadosavljevich
I think he meant the engine itself.
The Red Baron
The trick with pump life is fitting the priming bulbs with built in 1 way valves as all to often, the pump fails after filter change or due to leaking bleed off pipes or injector seals.
Quote from: Marks DTM Calib on 09 December 2015, 11:22:37
That reminds me...  ...its been sat in my garage for over a year  :-[
Quote from: TheBoy on 09 December 2015, 18:43:32
Just after 'the event' then?  ;D
Quote from: STEMO on 09 December 2015, 18:45:26
That was 2.5yrs ago :o
Quote from: TheBoy on 09 December 2015, 18:48:18
Jeez........I feel genuinely shocked at that. Where does it go?  :(
Quote from: STEMO on 09 December 2015, 18:49:37
Are you talking about time, or my ex-garage contents ;D
Quote from: TheBoy on 09 December 2015, 18:56:09
Oh we know where your contents went..........Mars.  ;D
