D'yer know what?
Started by STEMO, 09 January 2016, 19:48:53
I'm fed up buying these, that's three in two years now    :(
Ah, ok... not what I envisaged at all, but I can see why that would become irksome...
Presumably a full size one would devoid the car of all available boot space :-\
Quote from: Harris K Telemacher on 09 January 2016, 20:07:33
Salesman reckons the full size spare off the megane would fit and told me to 'steal' it before trading in, so we'll see.
Quote from: STEMO on 09 January 2016, 20:09:35
Is it under the car? You'll have fun doing that, as the designer is a sadist who used to design Mensa tests. You could read the 'instructions' but they're even worse.
Quote from: Nick W on 09 January 2016, 20:25:57
No. So no Mensa test for me.  ;D
It's in the boot, used once, with a brand new toolkit, which I'm avin too.
What's wrong with a can of goo anyway?  :-\
A lot easier than messing about by the side of the road in the pissing rain changing a wheel?  ::)  :P
Take cover Tig..... Incoming!!!!  :D  ;D
Quote from: Sir Tigger on 09 January 2016, 21:21:24
1) It doesn't work
2) If it does work, you need a new tyre afterwards, cause your old one is full of goo.
Quote from: STEMO on 09 January 2016, 21:29:47
1) It doesn't work
The can of goo doesn't work. It just gives you a false feeling of security, brought about the car manufacturer's cost cutting and the ridiculous size of modern wheels.
This is a very scary post for me; I find myself agreeing with Stemo because he's right :o
And the goo doesn't work.
It even says in the book that it's only an emergency fix to get you to kwikfit a tyre dealer.
The original bullshit was that the reduction in weight from not carrying a spare saved you money, but actually it saves them money cause a bottle of glue is cheaper than a spare wheel, and if the reduction in weight means they can creep below 99gms emissions, they can advertise the car as zero tax.
Quote from: Nick W on 09 January 2016, 21:58:30
1) It doesn't work
The goo dosn't work?  :o  Has anyone told Trading Standards?  ::)  :D  ;D
Bigron
OKO works, if you choose the right version for your application and doesn't get tyre fitters in a strop when removing the tyre eventually either!
Ron.
