Multiram valve number 2...(behind the coilpack)
Started by calibrated, 13 January 2016, 21:21:12
calibrated
What is natural position of multiram valve after 4000 rpm? Should it remain in position for example when engine is off or should it operate in direction of coilpack? (opening or closing inlet)
zirk
Open, there both open at full revs (shortest velocity).
Edit, both open at more than 4100.
terry paget
But note that valve 2 (in the plenum) must be open at idle on early engines with idle control valves on 2,4,6 side, but should close between idle and 3400rpm to give more torque. I have known them stuck open, so engine ran, with poor low rev torque.
Yep, I think it's open on all cars at idle to balance the airflow across the banks. It closes once the engine is under load, and opens again at 4100 RPM.
Webby the Bear
Not wishing to bump but...
I wanted to double check these were working prior to me doing my proper 0-60 test  :D I can't get either of them to move  :o though the car doesn't seem down on power particularly.
So. just so I've got this right...... whilst looking at the rear multiram (plenum) it should move when throttle on...... then at 4100k rpm the front one in the trumpets should move. correct?
if so am I right that it has to be stuck open/closed valves? as I believe any electrical issue will put the EML on (something I found when I forgot to plug it in  ::))
RIP Paul Lovejoy
Webby the Bear
ps, just to add I do have hissing when vac lines pulled from vac tanks...so I knowthey are good :)
RIP Paul Lovejoy
Webby the Bear
Anyone?
Just to add I got the front one to move. But the rear plenum one is definitely not moving.
I have a spare plenum. Is it worth swapping the valve. Or maybe sticking the spare plenum on. I don't believe it can be electrical as it would throw a code. Any advice welcome.
Ps got the front one to move. Previously I must not have revved it hard enough
RIP Paul Lovejoy
Quote from: Webby the Bear on 23 January 2016, 19:48:19
Anyone?
Swapping the plenums is as quick and easy as swapping the solenoid and valve :y
Webby the Bear
Quote from: Harris K Telemacher on 23 January 2016, 19:52:10
Anyone?
Cheers mate. Got to take plenum off anyway as I got some breathers to clean too 👍
RIP Paul Lovejoy
Webby the Bear
Is the rear multram from a 3l plenum fittable to the 2.5l plenum? It's the only one I have spare. Gutted as I thought I had the full plenum. Grrr
RIP Paul Lovejoy
Quote from: Webby the Bear on 24 January 2016, 14:42:50
All the multiram items are the same :y
Webby the Bear
Quote from: Harris K Telemacher on 24 January 2016, 14:44:29
Great news. Thanks Taxi  :y
With the car off I moved the plunger and it seems to move with ease. There was a slight air escaping / sucking type noise from the diaphragm looking thing. Possible air leak causing it not to move I wonder  :-\
RIP Paul Lovejoy
DrAndyB
I would be interested to hear if you get to the bottom of your issue, as I am convinced my rear multiram is the same.  Front multiram Definitely moves when blip above 4k rmp but rear not move at all.  Moves freely enough when press plunger and no noticeable air escaping and connector to solenoid is in  :-\
Keep posted of your progress  :y
