Silver Bullet Mot Advisory Thread 2016
Started by 05omegav6, 30 January 2016, 18:19:01
Any advances on the following:
1. Alleged Windscreen obstruction.
2. Sill covers.
3. General chassis corrosion.
4. Oil leak.
5. Handbrake return spring mountings corroded.
6. Front inner wings corroded.
7. Rear inner sill corrosion.
8. Sidelight bulb.
:D
Edited to correct...
I'll state here and now, the air freshener left dangling from mirror was not an adviso. I forgot all about it, but found it hanging from indicator stalk as I drove it home.
So not windscreen obstructions :)
EMD
Water leak
Front chassis legs rotten
Rear doughnuts
Front main beams like candles
Wipers worn
Omegatitis
pauls
Worn rear tyres near legal limit.
front disks and pads near legal limit.
Quote from: pauls on 30 January 2016, 19:02:43
I didn't think there was?
Quote from: TheBoy on 30 January 2016, 19:58:01
They're required to have some material left... ::)
Quote from: Harris K Telemacher on 30 January 2016, 19:59:16
I'm sure I slapped on new pads already this year.
I'm saying nowt, mine must be due again soon :-X
.. Hence my rush to the motor factors the day before MOT. ::)
Quote from: EMD on 30 January 2016, 18:39:19
Water leak
Rear doughnuts
Wipers worn
And you scored...
...a big fat zero
I'm truly amazed that this old dog wasn't cubed years ago. :)
Quote from: TheBoy on 31 January 2016, 10:20:48
Water leak
Rear doughnuts
Wipers worn
And you scored...
...a big fat zero
Dread to think what I got then :o Was hoping for at least a 4... :D
Quote from: TheBoy on 30 January 2016, 18:31:04
But was it a fail?  then moved for the retest?
Im gonna go for :
plastic over sill fitted
both n/s/r & o/s/r wheel arches corroded and holed
under side corroded and rusty
both front brake disc corroded and rusty
both rear brake disc corroded and rusty
both rear hubs back plates corroded and very rusty
nearside rear Tyre worn very close to legal limit
offside rear Tyre worn very close to legal limit
oil leak sump pan very rusty
EMD
Omegatitis
