Author Topic: 2006 Ford Ka rear spring replacement  (Read 5794 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 21 March 2016, 18:58:35 »
Evening gays, I mean guys. how are we???
got the above job in tomorrow for an MOT repair. are they easy (i.e. unbolt shocker, leaver shock down and remove / replace). or are they really difficult like the ford focus rear springs?
I'm hoping the former  :y
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: 2006 Ford Ka rear spring replacement
« Reply #1 on: 21 March 2016, 19:08:20 »
I think you'll find it very similar to doing  front struts. remove the coilover, compress the spring and undo the topnut.
Webby the Bear
  • Northampton
« Reply #2 on: 21 March 2016, 19:14:03 »
oh I see, the shock goes through the spring like a strut then on these?
cheers nick. I always like to look at the next days jobs and research them the night before so I have as much info as poss. however cant find anything on these on the net! and im buggered if I can remember the set up from memory  :y
RIP Paul Lovejoy
« Reply #3 on: 22 March 2016, 08:19:15 »
Yes, they have a small spring that fits around the upper half of the shock.
From personal experience, you will, find the shock will be equally as shot (compress it and it wont return)
Webby the Bear
  • Northampton
« Reply #4 on: 22 March 2016, 18:35:39 »
Tha you ladies. Piece of pish in the end........after 20 minutes I figured out that little circlip was holding the top mount on  ::) ;D
Never seen that circlip set up before hence why I was initially confused.  :y
RIP Paul Lovejoy
baggers
  • Heywood, Mcr
    • Omega 3.0 & 2.2
    • Carlton, Senator, Omega Spares.
« Reply #5 on: 22 March 2016, 19:33:38 »
Yes that little clip hidden away, makes you wonder how it holds.  If you feel tough you can just compress it enough by hand and get someone to flick it out  ;D
