Lambda sensor recommendations
Started by Jimbob, 14 April 2016, 18:26:58
Need a new rear sensor : 9199469
Best part of £150 at Vauxhall
Online, varying makes from £20 upwards, along with seeming different part lookup references on different sites.
Anyone recommend a good value & reliable replacement for a 3.2 rear sensor?  Cable lengths seem to differ too, and as the bosses are further back than standard.....
Or do I have to go and bend over :(
Quote from: Jimbob on 14 April 2016, 18:26:58
Branded NGK are a good bet. Cheap ones might need your plug soldered on.
NGK dont actually list a replacement....without soldering, and i'd rather buy complete.
ted_one
NGK's just been fitted on the 3.0, straight fit, job's a good 'un :y
Is it the one with the longer cable? Got a believed good second hand one here... 470mm :y
biggriffin
Ngk, this way too. Extended using old wire and a soldering iron and shrink tubeing :y
Hoof'land storeman.
Quote from: Harris K Telemacher on 14 April 2016, 18:49:46
How much you looking, HKT
Quote from: TheBoy on 15 April 2016, 17:01:29
Pm your thoughts ;)
baggers
Which NGK are you all fitting?
I can only find a direct swap for the front.
Rear not available for 3.2
There is a insignia 3.2 available, but thats a different part number and cable length.
For the rear sensor I think I'd just chance a generic. Better still, an NGK/Bosch branded generic sensor.
They're only there to keep the EML off and don't get the heat that the front sensors do.
You'll probably need to cut the connector off the old one and solder and heat shrink onto the new sensor, but no real hassle.
