Author Topic: fitting 3 litre cats to a 3.2  (Read 1579 times)
omprezaman
« on: 27 May 2016, 06:38:18 »
Has anyone fitted 3.0 litre cats to a 3.2? Is it a simple as in are the pipe lengths and shapes the same, what happens to the precat sensor as I presume the 3.0 only has 1 sensor per pipe whereas the 3.2 has 2, also are there any advantages to doing this, if so what? My 3.2 needs a new pair of cats and was considering the 3.0 cats as an option as for one reason I can get them cheaper than 3.2 cats. Also to note the car has a cat back high flow stainless exhaust. Thanks
ted_one
Re: fitting 3 litre cats to a 3.2
« Reply #1 on: 27 May 2016, 07:35:07 »
Both of my 3.2's have been done,they were virtually a straight swap but with a small amount of fettling which someone will be along to tell you what's needed, as I didn't do the work but as usual stood and watched : ::):)I brought the approved version of the 3.0 ltr cats as I wasn't to sure wether the emissions would be affected on the MOT,they cost a bit more but the cars sailed through the MOT. :y
« Reply #2 on: 27 May 2016, 07:42:20 »
Have a look here :
http://www.omegaowners.com/forum/index.php?topic=104510.msg1308946#msg1308946
basically need to add in the extra lambda sensor, and remove some of the flange.
omprezaman
« Reply #3 on: 27 May 2016, 12:07:10 »
Thanks, don't think I will have issues with emmissions as it can run on lpg. does it have any noticeable advantages nitro? Thanks for the link jimbob .
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 27 May 2016, 20:11:12 »
Done mine,  :y
Hoof'land storeman.
