Fitting an AR35 from Senator
Started by Shackeng, 21 July 2016, 09:49:32
Use dipstick to fill... Hole will be about the same diameter ;)
Shackeng
Quote from: Doctor Gollum on 25 July 2016, 16:59:47
Sorry, I don't follow that Al. :-\ :-\ :-\
Shackeng
The ECU is now identified positively as the auto transmission ECU for a Senator, which I shall sell as no use to me. :y
Shackeng
If you mean use the dipstick tube to fill the box, I doubt this will be possible. If you look at the pic above, the tube inlet will be inaccessible when the box is fitted. :y
Mr Gav
Quote from: Shackeng on 25 July 2016, 17:18:04
A close up of the dipstick and tube would be handy, when fitted it goes (or should) up to the bulkhead in the engine bay on the drivers side  :y
Mr Gav
Shackeng
Thanks Mr G, that makes sense, as I think the oil it being poured into an extension of the tube I have got fitted. I'll post a pic of the top of the tube for interest. :y
I suspect you have a Haynes for the Senny. ::) :y
Slightly off topic, but that was exactly the same method of filling the autobox on the Ford Granada Scorpio .... remove dipstick, fill, replace dipstick !!  :)
Quote from: Entwood on 25 July 2016, 21:38:49
They neglected to fit a drain plug on the A4LD though, effectively sealing it for life ::)
Quote from: Doctor Gollum on 25 July 2016, 21:41:11
Mine was modified with an external transmission cooler for towing so had a drain tap placed in the line, wasn't needed in France when a seal failed and it was getting through 5 litres of ATF/100 miles !! but she made it to the Loire Valley where she went off for repair and I drove a brand new C5 for a couple of weeks (underside of the car and the front of the van were an odd shade of pink for a long time after !!!)
It was the procedure on pretty much every automatic until some oppswit decided to delete the dipstick.
Mr Gav
Quote from: Shackeng on 25 July 2016, 21:21:51
I do have one indeed, possibly two even  ;)
Shackeng
Can anyone shed light on pics 2 & 3? Is the square drive at the rear of the box a speedo offtake? And why did they fit an selector shaft on each side of the box? given its an auto. Or could the RH shaft have been for some sort of position indicator? :-\ :-\ :-\
Mr Gav
Quote from: Shackeng on 25 July 2016, 22:44:43
Picture 3 is the speed signal output IIRC, there is a black cylinder shaped signal generator that bolts on there with a two wire output, it`s the same on the manuals.
When I get home tonight I`ll have a look at the manual and see if there are any photos, it was a while ago since I had my Senator now and the auto box was short lived, it went to thr tip after converting it to manual.
BTW if you want the manual, if it is any use to you, PM me your address and I`ll post it on  :y
The hollow square drive is for a traditional speedo cable. The cable retaining nut screws onto the large threaded body.
