Fitting an AR35 from Senator
Started by Shackeng, 21 July 2016, 09:49:32
Quote from: Doctor Gollum on 22 July 2016, 12:38:48
Quote from: Marks DTM Calib on 22 July 2016, 09:54:14
Given where the gearbox dipstick sat on the senator, there is no way it will work with a V6 in there.
Believe Shackeng is putting this box in the 2.5tdi... straight six too...
Still suspect it will be a struggle, the inlet setup on the TD is pretty large and the engines in the Omega are set slightly further back on the Senny
Shackeng
Quote from: Mr Gav on 26 July 2016, 07:39:49
Quote from: Shackeng on 25 July 2016, 22:44:43
Can anyone shed light on pics 2 & 3? Is the square drive at the rear of the box a speedo offtake? And why did they fit an selector shaft on each side of the box? given its an auto. Or could the RH shaft have been for some sort of position indicator? :-\ :-\ :-\
Picture 3 is the speed signal output IIRC, there is a black cylinder shaped signal generator that bolts on there with a two wire output, it`s the same on the manuals.
When I get home tonight I`ll have a look at the manual and see if there are any photos, it was a while ago since I had my Senator now and the auto box was short lived, it went to thr tip after converting it to manual.
BTW if you want the manual, if it is any use to you, PM me your address and I`ll post it on  :y
Thanks, I thought it was. No, don't need the manual thanks, as I just need that info on the odds and ends extra on the box. :y
Shackeng
Quote from: Marks DTM Calib on 26 July 2016, 08:14:04
LH side Mark. :y
Mr Gav
Quote from: Shackeng on 26 July 2016, 10:05:42
I`ll have a look tonight and post up some relevant pics, there`s not much on the auto box though, no exploded diagram.
Shackeng
What looks like a selector shaft on the RH side directly opposite the normal selector. :-\
Full pic of the dipstick tube. It is mounted in a rubber sleeve, and easily removable, but how to safely block the aperture? :-\
omegod
Tap it and put a bolt in or an aftermarket sump plug kit?
Quote from: Shackeng on 26 July 2016, 13:35:17
Cut down the tube so that there's about 20mm left. weld a plate over the end and refit as normal.
The sump isn't going to be pressurised on the autobox, is it? (I don't think) .. most likely that yellow cover already fitted at the end of the stub would be fine, assuming the stub of dipstick tube clears the firewall.
Quote from: aaronjb on 26 July 2016, 15:34:28
That's going to be as secure as a dipstick shoved in the end, so yes, I'd say leave it at that.
Incidentally I suspect this is what would normally fit on the end over that rubber O-ring and snake it's way up the rest of the firewall on the Senator: http://www.ebay.co.uk/itm/FILLER-TUBE-for-AR25-AR35-AUTO-GEARBOX-Senator-B-/360283397015
If you really want that easily accessible fill tube, maybe that could be bodged modified to fit the Omega firewall.
Shackeng
Quote from: aaronjb on 26 July 2016, 15:55:53
Hmm, its a thought. However I have now removed the existing tube from its rubber mounting seal, and, hooray, found a perfectly tight fitting rubber bung from my rubber seals/stoppers gash box. You know the type, with several concentric rings of rubber around the core. It fits perfectly, and is a tighter fit in the seal than was the tube, so I don't think it will be a problem, and as you say Aaron, the sump is not under pressure .
Thanks all for your suggestions, all workable I would think. At least with this solution, I will not be offering the box up, only to find that something interferes with the tube. :y :y :y
Shackeng
Any ideas what the RH 'selector shaft' may have been for.? :-\ :-\ :-\
Mr Gav
Thats the route I would be going down, I`m pretty sure it could be made to clear the firewall and it gives you fuss free filling.
biggriffin
Can't see oil cooler pipes on new box.
Selector shaft was done for different applications,
Hoof'land storeman.
Mr Gav
Quote from: biggriffin on 26 July 2016, 19:07:52
I think they`re on the other side, Senny definitely had them  :y
