aux belt tensioner
Started by raywilb, 13 August 2016, 18:33:06
raywilb
I bought a belt tensioner from ecp and fitted it. I used the same bolt & I thought it was queer the bolt got tight & I had to put washers on it to avoid doing thread damage. when I put the belt on it sat a little bit proud of the actual tensioners wheel whilst being ok on all the other pully,s. I know its an easy fix by putting a 8mm or so shim behind the the two fixing points to bring it more inline with the pulleys & allowing the belt to sit fully on the tensioner wheel
biggriffin
It's easier to repack the bearing with hm grease.
Hoof'land storeman.
raywilb
Quote from: biggriffin on 13 August 2016, 19:19:56
I need to bring it out from the engine a bit to enable that pulley on the tensioner to fit the belt squarely on it , at the mo the belt is slightly proud of roller,.
BazaJT
Sounds more like they've supplied the wrong tensioner.After all you shouldn't have to pack it out with anything for it to fit properly.
raywilb
Quote from: BazaJT on 14 August 2016, 12:00:24
it came marked up for my car. ( made in E Europe )
biggriffin
Quote from: raywilb on 14 August 2016, 14:55:33
Via china.
Hoof'land storeman.
It doesn't fit.
Take it back & get your money back.
From memory a genuine one is £35 from a VX dealer.
steve6367
Quote from: Andy H on 15 August 2016, 09:10:00
It doesn't fit.
Second that, get the correct part - if the belt breaks it could take the cam belt with it  :D
Quote from: steve6367 on 15 August 2016, 09:33:02
It doesn't fit.
Isn't a 2.2 diesel chain driven?
But you are all correct, the pulley should just bolt on with no alignment issues. The part  the OP has been supplied is wrong and he should return it.
terry paget
Interesting comment, Biggriffin. I have suffered two tensioner bearing siezures, most embarrassing. Would you recommend greasing the bearings as a service procedure, say every 40000 miles, like cam belt change intervals? I take the tensioner off changing a V6 cam belt, greasing it then would be trivial.
Quote from: terry paget on 15 August 2016, 13:36:02
Yes... I grease mine every time it is taken off :D :y
As per both DVD and Guide... ::)
It is.
For the few seconds it takes to pry the seals off and add a smear of grease, there is no reason not to do it.
terry paget
Thank you gentlemen. I do not have the DVD, and the guide just says watch the DVD. I learned to change V6 cam belts from Haynes and Doc Omega on the Yahoo site before I mastered this site. I shall grease the aux belt tensioner henceforth.
biggriffin
Undo 15mm nut, take pulley, off, prise cover off bearing, re-pack with grease. Installation is the opposite of removel. :)
Hoof'land storeman.
