Wanted: V6 Injector Loom
Started by tunnie, 15 August 2016, 13:53:36
For the 3.2 LPG Project, I need a V6 Injector loom with the two grey plugs, I need as much loom on the other end as possible. 6-8 inches. (queue jokes here)
Thanks  :y
To clarify, this is the big grey plug for the injectors. Needs both plug and socket with the wire tails at least 6-8 inches, if not more. It is to build a new loom :y
zirk
I might have an upper 3.0 or 3.2 (cant remember which it came from, fairly sure their the same) inlet manifold complete with injectors and rail and its been pre drilled and fitted with LPG Injectors from a OMVL Dream system, also has the Soliniods / Relays and most of the Petrol / LPG Loom etc kicking around somewhere.
I sourced it years ago for my 3.0 LPG Irmscher, as the one fitted on the car was fitted by the Installer by drilling the upper Penlium and injecting from the top, so I was going to swop / correct it etc.
I sold the car a few years back now, and honestly cant remember if I left it in the boot for the new owner or not, will need to check.  :-\
Quote from: Doctor Gollum on 15 August 2016, 14:48:00
Quote from: tunnie on 15 August 2016, 14:24:23
Thanks for clarifying  :y :y
Might have one here...
ECU to injector loom...
Required to connect the lpg side to the petrol injectors...
Quote from: Doctor Gollum on 15 August 2016, 15:35:58
Need the other half of it too ;)
Thanks  :y
Do you have just the one?
Quote from: zirk on 15 August 2016, 15:09:54
Thanks  :y
Let me know if you do, as I was going OMVL injectors anyway. I guess I could just swap the petrol injectors over if it's a 3.0 manifold.
It's the only half I have...
VXL V6 can show you a picture of my spare injector loom as it's built into his LPG loom :y
Of the two halves, the one pictured is rarer as it usually stays on the car when scrapped, whereas the injector loom tends to come out with inlet manifold/engine ;)
Quote from: Doctor Gollum on 15 August 2016, 16:34:05
Indeed... Don't bin it ;D
zirk
Have you bought the LPG Kit yet Tunnie?
Cheers. How much do you want for it?
Quote from: zirk on 15 August 2016, 21:44:27
Not yet, been listing all bits and bobs in a spreadsheet from LPG site, will prob order towards end of the month  :y
steve6367
Quote from: tunnie on 16 August 2016, 00:11:21
Would you mind sharing the spreadsheet when you get there?
I believe I have one of the injector looms from under the plenum. Will have to double check. Free to good home.
