Shaving
Started by Mr Skrunts, 16 August 2016, 23:46:47
Having had a beard since 1992 i decided to shave it off a few weeks ago, considering a change in blades (Brand/type) and keep toying with the idea of a cut throat razer :-[
Then over the last few days have seen the Phillips Oneblade on tv.
Just looked them up on the net and there a re a few models varying in price. :-\
Just wondered what peoples preferences were and do the the 5 blade edges make a difference from the double edge razors. ::)
Also has anyone got/used the Phillips Oneblade.
Cut thoat razors, any one use them ? :y
Quote from: Mr Skrunts on 16 August 2016, 23:46:47......
I've not use one, but a lad at work tried one recently & was quite impressed ..... and he has a fairly heavy beard  :-\
Varche
Going against fashion trends?? Havent you seen the latest must have is a beard
I grew mine when imanaged to resolve a very difficult case at work in 1983. Damn sight easier than the shaving milarkey.
Ps where will you keep snacks for between meals now?
Quote from: Varche on 16 August 2016, 23:58:42
aside from the moaning from SWMBO if I don't shave for a week or two, I find that it starts to drive me mad at much more than a fortnight ...... and I'd have to wear a snood at work!  ;D
Removing the signs of ageing in the process  ::)
You should trim your eyelashes while your at it Mr Skrunts!  ;D
biggriffin
#6
What about a Brazilian.  ;D well it is Olympics' week. :D,  Or a hipster.
Hoof'land storeman.
Personally a big fan of a traditional Double edge razor....
Ask your self this....
How many blades do you need for a good shave.....
A.  one GOOD one.
Ive used em for years, think they are better than the disposable cartridge razors, and saves a fortune!  and no more stretching a blade's lfe as they are so expensive.
Technique and timing also plays a big part, happy to expand on what I use or fav blades and soap etc if interested.
Mister Rog
I've just gone the other way, and recently grown a beard, not a full one, a sort of tache and chin.
The razor companies are constantly trying to come up with "next big things" to part us from our cash. Two blades, five blades, swivels, all of them at the same time with a face massage, and all very expensive. Tesco blue pack twin blades disposables. About £1 a pack of 10, just don't re use them too much. Job done.
"The desire to be a politician should bar you for life from ever becoming one." Billy Connolly
I went back to standard double-edged blades a couple of years ago because I'm allergic to the marketing wank of the cartridge blades. There's no noticeable difference in the results, each blade lasts for several shaves, and they're so cheap I'm not tempted to keep using one that is worn out.
Mr Gav
I use Wilkinson Swords extreme 3 razors, very good and give a nice close shave, I found Gillette used to cut me quite a bit even on first use but I`ve never had a problem with the extreme 3`s, I`ve used them for well over ten years now.
Oh FYI I shave my head with them too, it`s an all over shave apart from the goatee  :y
Quote from: Jimbob on 17 August 2016, 08:26:02
Yes please, that was another reason for this post but felt a bit awkward asking. :-[
My Father suggested when I started to shave to do the whole beard area, sadly I only shaved the bits that grew hair which was just my chin (which I did every time I felt growth with the 3 head Phillishave he bought for me)  plus the trend was we all grew a 'tache' and because it was never shaved has allways remained weak compaired to my chin but at at least has'nt gone grey yet. ::)
In my 20's when I started shaving with razors I liked the single blade (twist to lock blade) razor and in all fairness I preffered to the twin blade razor at the time. :y
I had a battle with the twin blade razor, tried all ways and directions of shaving but they were costing a fortune, took a long time to realise I was shaving wrong.  But the bigger problem . . . . . . . the other half . . . .shaving her legs with my razor and clogging it up  :-X :-X :-X
After 24 years of beard experiments, shapes, lengths and the pending hot weather (that they got wrong) then the beard was going.  To be fair, it was removed without with a Bic/Tesco blue double edge razor.
To my surprize I have shaved everyday since but thinking the beard might reappear  for winter. 8)
Not a problem, Theres many sites, with much, often conflicting, or perfectionists results which can make the whole task too much of a chore...
Ive digested a lot, and settled on an easy, but effective routine which is probably easy for anyone to adopt with a few changes to their normal routine.
1st, and probably most importantly, the time of day you shave....I always used to jump out of bed, shave, shower, dress, breakfast...Shaving the minute you get up is not good, stubble needs to raise and wake too.
So, get up, breakfast, shower 1st, then shave, your stubble will be more ready, sticking out more with pores open after a shower....
2nd, ditch the shaving gloop from a can.  Use a decent shaving soap with a brush, makes quite a difference.  I like quite a stiff bristled brush and soap,   Splash my face a few times with hot water, make a lather (I do this in the soap pot, nothing separate), and apply.
3rd, Shave, I start going top of cheeks down to neck line, smooth single passes.  I then re-lather (always enough left on the brush) I then go ear to nose direction across cheeks, then neck to chin upwards, then any attention to missed, or harder areas such as chin itself, mouth corners.  Mustache area just gets 2 downward passes.
4th, Splash face a few times with cold water and pat dry, I then use a bit of nivea post shave balm.
Thats it, If I wanted I could do a 3rd different direction pass...If I did this it would be so smooth I wouldnt need to / couldnt shave the next day, but done often would leave your face sore.
I swap between 2 brands of blades, a pack at a time.  If I always used the best one which is the sharpest, my face would soon end up a mess so give it a sort of rest by alternating to my 2nd favourite.
Hope that makes sense, simple but i find it effective.
If your interested I use the following,
Razor : http://www.shaving-shack.com/merkur-38c.html
Blades : http://www.shaving-shack.com/10-feather-hi-stainless-double-edged-razor-blades.html
or : http://www.shaving-shack.com/astra_platinum-double-edged-razor-blades.html
But if your starting down this route, you can buy large assorted packs so you can see what suits YOU the best
Soap : http://www.shaving-shack.com/mitchells-wool-fat-shaving-soap-refill-120g.html
Brush : http://www.shaving-shack.com/progress-vulfix-2235-super-badger-shaving-brush-cream.html
Plenty of other shops about, and loads of choice....but that lot works well for me.
Webby the Bear
There's only one decent razor on the market. Gillette Mach 3. The original one
Beautiful smooth close shave. With zero cuts every time.
Hth
RIP Paul Lovejoy
I recently bought a beard trimmer so go round with designer stubble (No. 2) these days and only shave for weddings, funerals and court appearances.  :y
On these occasions I use Lidl's Shark razors which are cheap enough and I have found them to be very good!  :y
