Author Topic: Unplugging cable from door motor  (Read 3074 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 20 August 2016, 10:34:07 »
I am struggling to unplug the cable from the lock motor. I have an old one to hand to show what I should do, but with my hand inside he door I cannot find the strength to wriggle it out. Is there a trick?
    • 530D M Sport, 330i Coupe
Re: Unplugging cable from door motor
« Reply #1 on: 20 August 2016, 10:47:07 »
Easier to do when you release the motor / lock mech from the door.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 20 August 2016, 10:53:20 »
Easiest way, find tags, push outwards then push down, all at same time, seems complex but does work.
Hoof'land storeman.
« Reply #3 on: 20 August 2016, 10:59:01 »
I get fingernails behind each tab, one at a time, wiggle it so that its down enough it cant relatch, then do other.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 20 August 2016, 11:44:54 »
Thank you gentlemen. I released the lock from the door as VXL suggested, then I could get hold of it better, and off it came. Collected several bruises, but no injuries.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #5 on: 20 August 2016, 11:50:12 »
The fun starts when your putting it back in  ;D ;D
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 20 August 2016, 12:56:17 »
Did you unclip the cable from the bottom of the door this makes it a lot easier but getting the cable clipped back is not so easy.
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 20 August 2016, 20:16:59 »
No. Once I had detached the lock frim the door frame it was no more trouble.
terry paget
    • 3 Astras 2 Vectra
« Reply #8 on: 20 August 2016, 20:25:22 »
Indeed it did. I got the lock tangled up with the upper rods, so removed the door lever frame. Then dropped one of the nuts, and then the rod from the door outer handle. then had to work out where everything went. Its a job I have done before more easily, without disturbing the opening lever assembly. Job is now done, door card back in place, and all faults cured. Thanks to all for help.
Steve B
  • Leicestershire
« Reply #9 on: 20 August 2016, 21:04:23 »
The way i do them is. Put lock inside door,then fit the rods with clips. then lift lock into place making sure you get the rod in the hole at the back while lifting up, then in with bolts   :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #10 on: 20 August 2016, 21:20:07 »
That's the way I find easiest.
Steve B
  • Leicestershire
« Reply #11 on: 20 August 2016, 21:28:35 »
I always fit a new micro switch first... so i no i wont be back there in 6 months   :-X
