Dash lights
Started by Lagondanet, 27 September 2016, 15:46:45
Lagondanet
Backlight behind temp gauge & rev counter has just gone out! Is it a pain in the arse to fix? How? Thanks.
Diamond Black Geezer
Removal of the dash binnacle is very nearly the same amount of time as it took you to type. So good news!  :y
Car unlocked, Key out, padlocked inside lead-lined container. Bury the container. Let no-one see you
Ping out centre vents
Find screw(s)
Remove the vent surround
You will see a screw(s) on the immediate left of the binnacle, undo
Binnacle pulls out, the left comes first, iirc
Unplug if required
find offending bulb, replace.
reversal is the etc etc...
Point 1 is there because I think, if you accidentally turn ignition on with the dash binnacle disconnected, a nasty light remains on, requiring Tech 2. Might have completely made that up, but certainly better safe than sorry  :) Apologies for the mixed sigular/plural of screw(s) can't remember the number, just their location  :)
EDIT: Must type faster!!!!  ;D ;D
I just used the mouse  :P  ;D
Yeah, well that's cheating!!  :D
Lagondanet
Thank you very much. (As I thought a pain in the arse.  ;D )  :y
It's a 5 minute job to remove  :y
Lagondanet
OK OK I'm a lazy bastard. Just getting a screwdriver out of the box tires me out.  ;D But I'll give it a go.  :y
Lagondanet
When the weather is good.
Lagondanet
When I have the time.  ;)
Scatmancraig had the binnacle out my spares car in the time it took me to walk to the boot to see if I had a screwdriver! I still think I might have narcolepsy, or something!
If you fancy a day out, it'll be done before the kettle boils :D
frostbite
I gave mine a tap or knock (whichever pleases you) and the light came back on, but not too hard
e46 325i se - 1.8vvti avensis liftback
One of my MID lights went out, the first drive I had in Pissy on the way to the MoT station. I said "oi!" and slapped the top of the dahs - hasn't gone out in 2 years since!  :D ;D :D
I suppose you've already tried this method? (if you have the time, of course  ;))
Lagondanet
I gave it a little tap but will try a bit harder this evening. Thanks all for the advice.  :y
