WiFi Woes
Started by Auto Addict, 23 October 2016, 09:10:43
Start
type:
Power Options
and hit enter
Click "Change Plan Settings" next to your current power plan, probably Balanced
Click "Change Advanced settings"
Expand PCI Express, then Link state mgmt.
Change both battery and plugged in to off
OK all the way out, then reboot.
Auto Addict
Quote from: TheBoy on 28 October 2016, 17:56:54
Start
type:
Power Options
and hit enter
It was already set to what you have suggested.
I like red cars
OK, beyond that, might be worth stopping the adapter being power managed - open adapters, then properties of the wifi adapter, Configure button, then Power mgmt. tab.
TD
Quote from: TheBoy on 30 October 2016, 18:12:37
Didn't AA imply in other posts that when he had the fault the lappy could see other networks and actually connect to a BT open network, but still couldn't connect to his router. Also a reset of his router cured the problem.
So, to me, that implied a problem with his router, not the lappytop  :-\
Auto Addict
Done - thanks :y
I like red cars
Auto Addict
Just happened again, no wifi on laptop, switched off router, waited 30 secs, restarted it.
No Wi-Fi on laptop
Rebooted laptop, WiFi back.
Phones and tablets were still connected.
I like red cars
TD
Quote from: Auto Addict on 31 October 2016, 17:28:27
No Wi-Fi on laptop
Instead of rebooting lappy next time,  try left button clicking on wifi symbol on the taskbar (bottom right) and click on your connection, then select disconnect and click on reconnect....may do the trick  :)
If the Windows 10 (and Win8, but less common issue) can see the network, but when attempting to connect, comes back with something like "couldn't meet the requirements", this is usually a driver issue, and often around the hw/driver's power management not being compatible with W8/W10 - often a case for W7/Vista era laptops.
Generally the OEM for wifi card, eg Intel/Ralink/Asos etc simply state they will not support W10, and without an OEM reference driver to rebrand, all bets are then off.
Auto Addict
Quote from: TD on 31 October 2016, 18:08:24
No Wi-Fi on laptop
Always the first point of call, but doesn't work.
I like red cars
Auto Addict
Quote from: TheBoy on 31 October 2016, 18:51:38
It's a Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC
I like red cars
Auto Addict
Quote from: Auto Addict on 01 November 2016, 08:07:06
Ah, doesn't support Win 10 :(
Can I update the card?
I like red cars
TD
Quote from: Auto Addict on 01 November 2016, 11:17:57
No, as the chipset will be soldered into the system board.
Have you checked to see if there is a bois update for your lappy? that might help, if there is  :-\
Gaffers
They are not always integrated on to the motherboard.  Sometimes they are separate and attached via ribbon cable.  Worth checking.
Auto Addict
Quote from: TD on 02 November 2016, 07:35:57
I did find out a few weeks after upgrading to Win10 that my laptop didn't support Win10 :(
But, as it was running OK I didn't bother to re-install Win7.
It's been running OK since the release of Win10 until about a couple of weeks ago, when the WiFi started playing up.
I think, but I'm not 100% certain, it has got a network card, but I can't find any info about upgrading it.
It's a Toshiba Satellite C660.
I like red cars
Gaffers
You can always disable it in the bios and use a tiny USB one that is Win10 compatible :y
