WiFi Woes
Started by Auto Addict, 23 October 2016, 09:10:43
Auto Addict
Quote from: Guffer on 02 November 2016, 23:37:16
You can always disable it in the bios and use a tiny USB one that is Win10 compatible :y
Or go Ethernet..... ::)
I like red cars
Quote from: Auto Addict on 03 November 2016, 12:38:18
Quote from: STEMO on 03 November 2016, 12:48:24
People don't seem to be fussy on these TP Link thingies that use your sockets to transfer wifi throughout the house, but I used one for years with no problems. You could just plug your laptop into a socket anywhere about the house.
Auto Addict
Quote from: STEMO on 03 November 2016, 12:50:46
I agree, already use them :y
I like red cars
Quote from: Guffer on 02 November 2016, 08:59:28
They are not always integrated on to the motherboard.  Sometimes they are separate and attached via ribbon cable.  Worth checking.
Its likely to be a mini PCIe and thus easily changeable :)
They tend to have shockingly bad reception and performance, so absolutely last resort.
Also, the £5 cheapies have crap drivers, but Win10 is likely to pick up most with OOB drivers
Auto Addict
Quote from: TheBoy on 03 November 2016, 18:45:07
Can you point me in the right direction please, to what I should buy?
I like red cars
TD
Quote from: Auto Addict on 04 November 2016, 07:47:00
A new laptop, spend your winter fuel payment on it   ;D :D
Seriously tho.....are you confident in taking a laptop apart, changing a part and more importantly getting it back together again?
Not doubting your abilities Mr AA , but even I would think twice about stripping a laptop....desktop no problem, but that's on a bit bigger scale...
Unless TB is about to become a volunteer  :) :D
Branded laptops are generally easy to strip, as the service manual will be downloadable from the manufacturer.
Even without the manual, they are pretty easy (ignoring Lenovo Ultrabooks - but then you'd have to be a bit retarded to buy Lenovo), but there is always that doubt when something won't unclip if there is a pesky screw.
Most PCIe slots on laptops are accessible from a small panel on the underside, or by removing keyboard.
However, in this case, I'd recommend a new, Win10 compatible, laptop.
TD
Quote from: TheBoy on 05 November 2016, 10:54:14
Guess I must be then ......
Wife's work laptop is a lenovo, she seems happy with it. Don't know much about them, but I believe this one was close to £700.
Auto Addict
#56
Ok, recommend me one.
http://store.hp.com/UKStore/Merch/Product.aspx?id=X0L85EA&opt=ABU&sel=NTB
http://store.hp.com/UKStore/Merch/Product.aspx?id=ECC_BUNDLE_6084305&opt=&sel=NTB
http://www.dell.com/uk/p/inspiron-17-5758-laptop/pd?oc=cn57820&ref=PD_Family
Or none of the above :-\
I like red cars
TD
Quote from: Auto Addict on 05 November 2016, 16:13:27
Or neither :-\
Depends what you use it for AA? and do you have a desktop as well?
I have a cheapo notepad, which is fine for internet/email/etc. Its light/thin/fast and has about 8hours on batt (as no mechanical hard DD)
but no good for using in 'anger'. It also doesn't have a dvd drive, but I have an usb dvd drive if needed.
I also have an i5 desktop with 4G RAM/500G system HD and 2x 1TB HD running as a raid (in case one of the drives pops its clogs)
Which I can use in 'anger' when I want to  :y
Auto Addict
Quote from: TD on 05 November 2016, 17:50:15
Or neither :-\
I tend to use the laptop, Mrs AA uses the desktop.
I like red cars
Quote from: Auto Addict on 05 November 2016, 18:16:21
What for, Mr AA, so we can recommend a spec :)
