WiFi Woes
Started by Auto Addict, 23 October 2016, 09:10:43
Auto Addict
Quote from: Guffer on 23 October 2016, 13:36:57
You haven't switched on MAC filtering by accident have you?
Can you get in to the LAN logs on the router (via Ethernet) to see what is happening?
No.
I like red cars
Auto Addict
Quote from: Jimbob on 23 October 2016, 15:26:36
Assuming youve made no real changes to the router....try a factory reset, could be quicker and easier than pissing in the wind without a proper look at both the router and pc config.
Tried it again - all now working :y
Thanks Jimbob :y
I like red cars
Be nice to have got to the bottom of it. But not very realistic. Service restored will do :-)
Rods2
Quote from: Jimbob on 23 October 2016, 18:50:27
Not always possible as even if not a software bug 'normally robust software and hardware' can suffer from a multitude of problems due to very unlikely external events from cosmic rays, natural radioactive decay, soft memory errors, to emf and emp. Hard reset and start again is never a bad option to try. :y
biggriffin
I blame the Russian's, they needed more space for their little flotilla ;)
Hoof'land storeman.
Quote from: Rods2 on 24 October 2016, 03:06:01
Cosmic rays? Should I put my tin foil hat on?  :o
Auto Addict
Yes, I don't think I restored it properly the first time :-\
I like red cars
Quote from: Auto Addict on 23 October 2016, 10:38:29
Home Hub 5 type A
Just comes up with 'Unable to connect to the network'.
I've re-entered the password.
Windows 10 on an older laptop I presume?
If so, it will reoccur...
Auto Addict
Quote from: TheBoy on 24 October 2016, 18:23:11
Home Hub 5 type A
Thanks for that :(
I like red cars
TD
Quote from: Auto Addict on 25 October 2016, 17:42:46
Home Hub 5 type A
Thanks for that :(
TB must be mellowing in his old age....at least he didn't tell you use a sledgehammer to fix it  ::) ;D
Home Hub 5 type A
Thanks for that :(
Is it Win 10 on an older laptop then? If so, I'll make the effort to walk you through a possible fix :)
Auto Addict
Quote from: TheBoy on 26 October 2016, 18:14:03
Home Hub 5 type A
Thanks for that :(
It is, look forward to a possible fix :y
I like red cars
Careful AA, step 1 might be "Locate your largest lump hammer" ;)
Auto Addict
Quote from: aaronjb on 27 October 2016, 08:57:34
;D
I like red cars
Shackeng
At least he might be able to, TB's is still in orbit. ::)
