Wanted screen washer filler
Started by Shackeng, 09 November 2016, 12:13:39
Shackeng
As above, the screen washer bottle filler neck and dipstick for a PFL or MFL.
TIA
Will have a rummage, might have one  :-\
Shackeng
The Red Baron
Got the neck and lid but no dipstick.  :)
Shackeng
Quote from: The Red Baron on 09 November 2016, 22:04:32
Thanks Jon, but not much use without it. :(
The Red Baron
Quote from: Shackeng on 09 November 2016, 22:44:46
No.they usually fall off into the reservoir. ;)
Shackeng
I'll take the whole screen washer bottle if someone has one. :y
tidla
Quote from: The Red Baron on 09 November 2016, 22:49:40
Thats where i keep mine.
Bigron
Mine too; I iknow it won't get lost there!  :y
Ron.
Had a rummage but it isn't immediately obvious :-\ I know I had one as I acquired it especially for the plod one as the grill lights fouled the factory one, but it didn't reach the slam panel as the bottles are also different  ::) so I didn't use it...
I did however find a good condition facelift bottle and neck, no lid... if that's of any use :-\
It's a plod one, so has two pump fittings and no level sensor hole ;)
Shackeng
Thanks Al, but I need the PFL or MFL one to replace my FL one, as I can see the yellow dipstick top through the grille, and the longer one cannot be seen. :y
