bulbs in display
Started by robson, 29 April 2017, 17:54:25
robson
how easy is it to examine bulbs in the clock, time.temp etc display. My display is quite dim .Or could it be the rheostat at fault.
They should brighten/dim appropriately as you move the wheel... But they do blacken over time, before failing...
No response is more likely the bulbs than the rheostat :y
If the dash backlighting (with lights on) adjusts with wheel, then it'll be bulbs in the MID/TID.
Remove instruments (5mins), then you have full access to the bulbs for the MID/TID, they are the type you turn through quarter turn, then they lift out.
frostbite
Remove the 2 centre vents with the flap closed so the screws dont fall into the abyss of the mig, and remove the vent assembly.
Then lift off the top half of the cowling, should just pop off.
You should be left with 2 screws, one to the left of the M/TID and one above the steering coloumn.
Once removed the whole binnicle will lift out from the left, There will be one or two leads from the mid to disconnect and it can be freed.
dont be tempted to have the keys in while doing the job.
e46 325i se - 1.8vvti avensis liftback
There is a video and guide in maintenance guides section.
robson
The display light changes  with lights on and rheostat moved. Lights off no change in display when rheostat moved. That sounds correct? so its bulbs? I will look at guide :y
Quote from: RumpelStiltSkin on 01 May 2017, 13:32:27
There's a maintenance guides section... :o who've thunk it ::)
Quote from: robson on 01 May 2017, 13:52:43
Rheostat only works lights on, but sounds like your bulbs are past their best :y
robson
Cant find the correct guide can you GUIDE me :-[
frostbite
robson
Thanks for your help :y
