intake manifold cleaners
Started by raywilb, 09 June 2017, 21:03:01
raywilb
do any of the intake manifold cleaning sprays that are on the market actually work.?? :-\
serek
Quote from: raywilb on 09 June 2017, 21:03:01
If you have all taken a part , would say soak in diesel and then a lot of brake cleaner
Carb cleaner does the job, or a soak in diesel as suggested  :y
Paint stripper works ok as well.
zirk
Alloy Foam Wheel Cleaner from Poundland and a paint brush, then just rinse off.  :y
biggriffin
Hoof'land storeman.
Migv6 le Frog Fan
raywilb
the spray I meant is one that is sprayed direct into the inlet manifold in short 3 seconds bursts. a molyslip product. hey or nay.
zirk
Quote from: raywilb on 10 June 2017, 11:04:00
Not for me, just rip the intake Hoses and Throttle Body off, give it a good clean, I can do a V6, Penlium off, TB's, front and back Multi Rams, breather pipes etc, within 30 to 40 mins, so a 2.2 shouldn't take more than 20 mins, proper job done rather than spraying and getting crap in your engine.  :y
Lizzie Zoom
Carb cleaner from Halfords I find to be the best ;)
raywilb
Quote from: zirk on 10 June 2017, 12:05:52
its a dti . Ive seen a clip on utube where a guy was spraying a molyslip product directly into manifold. I guess only way is off  & a clean.  though last Wednesday I paid a garage for doing this. suspitions and tell tale signs are it wasn't touched
Lizzie Zoom
Quote from: raywilb on 10 June 2017, 14:36:52
A year ago I inquired how much my Vx dealer would charge to clean my breathers; £200, but that was without TC!! ::) ::) ::) :o :o
Needless to say it is a job I still do myself ;)
Take a look at the pictures MDTM posted up of my (Zafira) DTi intake, that will answer:
1) Why such a product won't work
2) Why you wouldn't want it to work
raywilb
Quote from: TheBoy on 12 June 2017, 17:06:20
cannot find the post. have tried.
