Carpentry advice
Started by Jimbob, 18 June 2017, 18:02:57
My son currently has one of those high sleeper beds, with loads of space underneath.
3 issues are occuring, 1 he needs a new mattress (ideally thicker than the higher sleeper will take as he is getting bigger)
second, he keeps banging his head on the ceiling
the third, he has a drum kit underneath which size is getting a little tight for.
He is in the smallest room in the house, so this has worked well up to now, but I need to change things around.
In order to fit everything in, I need a bed on the 'short' wall  This is perfectly long enough for a mattress, but you wouldnt get a divan bed in.
We could also do with storage underneath.
So the plan is to make a bed, effectively using batterns screwed to the 3 (brick and solid plaster) walls, piece of board on the top, extra leg in the middle of the 1 unsupported side.
This will maximise his floor space leaving room for chest of drawers, drum kit etc, and bed will be high enough to slide storage boxes underneath, couple of shelves on walls etc, Job Done!
Where I am stuck, is basically what materials to use.
was thinking 3x2's on the 3 sides, held on by something like these I guess : http://www.screwfix.com/p/fischer-fsa-sleeve-anchors-silver-12-x-96mm-m10-20-pack/59188
4x2 on the open side in order to have overlap to hide the board
3 x 3x2 batterns between the long sides (parallel to short sides), with a 'table leg' style support on the centre one (room end)
then for the base board, was thinking 3/4 ply? screwed down to all the below wood.
Does this sound appropriate, if you can visualise what I mean?
Can then paint the 1 visible side to match the woodwork, chuck a mattress on, and all done and dusted.
Lincs Robert
Sounds good, just make sure the "open" side, the 4x2, has the 4 inch part vertical .....
Quote from: Lincs Robert on 18 June 2017, 18:26:28
Yup, thats the plan so the board can sit behind and level with it, and not have the other batterns visible at the corners
If a mattress will fit, a divan bed without headboard should?
redelitev6
 ;D A bed ? when i was a lad i had to sleep on the  etc etc
Quote from: redelitev6 on 18 June 2017, 20:11:36
On the etc etc....? Bloody luxury.......
Rods2
If the bed has a roof to keep the rain and snow off, pure indulgent luxury, they don't make yoof like they used to. ::) ::)
Viral_Jim
#7
Quote from: Jimbob on 18 June 2017, 18:02:57
Unless your son has a bmi of about 946, I'd say these were a wee bit overkill!  :o the problem you're likely to encounter is that drilling an M10 hole, followed by ratcheting that steel outer sleeve into it is likely to "pop" a brick, unless you hit it bang on centre (pretty hard to do blind through the plaster).
Personally I would use these.
http://www.screwfix.com/c/screws-nails-fixings/hammer-fixings/cat840070?cm_sp=managedredirect-_-screwsfixings-_-hammerfixings
M8 is plenty, basically drill the hole, poke the plastic outer sleeve through the wood and into the wall, then hammer the metal centre in after it.  :y I've held up ceilings with these (and hung off the framework) no bother. So that's 21stone plus the woodwork. I reckon they will probably be man to the task of supporting Jimbob Jr ;)
Ill have a nose at those, the fixings were the bit I was least sure of.
Quote from: STEMO on 18 June 2017, 18:50:23
Without skirting boards, power sockets etc, it may just about squeeze in, but dont think you could manouevere it in successfully hence the build it option.
Could possibly assemble a frame bed, but they tend to have headboards.  this should be better in the long run
Quote from: Jimbob on 20 June 2017, 08:27:15
Hmm....couldn't you raise the level of the base to get it above the skirting? Bits of wood to act as legs? As for the socket, if it's a flush fitting, just use those kiddiproof blanks to blank it off, or remove it altogether.
Save an awful lot of work.
Its the only socket in the room, so HAS to be used.
The work has to happen, only way to get a bed, electrics, all his stuff and storage in there, its just exactly how to do it to sort out
