Author Topic: One for the networking experts  (Read 17029 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« on: 29 November 2006, 17:51:10 »
Got home yesterday to find that my desktop pc will only show the page below.
http://194.73.73.112/dns/dns-splash.htm
I'm not using BT yahoo any longer and now connect through a modem router.
All other pcs can browse fine so I don't think its a router problem.
I've tried various addresses and only get success if I use IP address not url.
Dns and default gateway for the ethernet connection are both pointing to the router and the nic is set with a static IP.
Tried pinging and internal addresses are fine, external ip addresses work as they should but all URLs get resolved to 194.73.73.50 then ping ok to that server.
Any of you network experts point me in the right direction please?
TuBy's new whipping boy.
Re: One for the networking experts
« Reply #1 on: 29 November 2006, 17:55:27 »
I think those servers are being decommissioned. What DNS is your router using?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #2 on: 29 November 2006, 17:58:22 »
208.67.222.222 and 208.67.220.220
which is working fine for this laptop, wifes laptop and eldest lads pc upstairs
« Reply #3 on: 29 November 2006, 18:04:28 »
have you restarted the dns client service on the duff machine? Or try a ipconfig /flushdns
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #4 on: 29 November 2006, 18:07:38 »
flushed dns a few times, I assume a reboot would restart the dns service if so yes
« Reply #5 on: 29 November 2006, 18:09:44 »
and ipconfig /all shows pc is using router for dns?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 29 November 2006, 18:09:46 »
Just restarted dns service and flushed dns i still get this
C:\Documents and Settings\John.JOHNS>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
C:\Documents and Settings\John.JOHNS>ping omegaowners.com
Pinging omegaowners.com [194.73.73.50] with 32 bytes of data:
Reply from 194.73.73.50: bytes=32 time=35ms TTL=49
Reply from 194.73.73.50: bytes=32 time=32ms TTL=49
Ping statistics for 194.73.73.50:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 32ms, Maximum = 35ms, Average = 34ms
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #7 on: 29 November 2006, 18:12:33 »
C:\Documents and Settings\John.JOHNS>ipconfig /all
        Host Name . . . . . . . . . . . . : johns
        Primary Dns Suffix  . . . . . . . :
        Node Type . . . . . . . . . . . . : Unknown
        IP Routing Enabled. . . . . . . . : Yes
        WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
        Connection-specific DNS Suffix  . :
        Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter
        Physical Address. . . . . . . . . : 00-50-8D-FD-8E-8E
        Dhcp Enabled. . . . . . . . . . . : Yes
        Autoconfiguration Enabled . . . . : Yes
        IP Address. . . . . . . . . . . . : 192.168.0.104
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        IP Address. . . . . . . . . . . . : fe80::250:8dff:fefd:8e8e%4
        Default Gateway . . . . . . . . . : 192.168.0.1
        DHCP Server . . . . . . . . . . . : 192.168.0.1
        DNS Servers . . . . . . . . . . . : 192.168.0.1
                                            fec0:0:0:ffff::1%1
                                            fec0:0:0:ffff::2%1
                                            fec0:0:0:ffff::3%1
        Lease Obtained. . . . . . . . . . : Wednesday 29 November 2006 11:33 am
        Lease Expires . . . . . . . . . . : Thursday 30 November 2006 11:33 am
Tunnel adapter Teredo Tunneling Pseudo-Interface:
        Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
        Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-00
        Dhcp Enabled. . . . . . . . . . . : No
        IP Address. . . . . . . . . . . . : fe80::5445:5245:444f%5
        NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Automatic Tunneling Pseudo-Interface:
        Description . . . . . . . . . . . : Automatic Tunneling Pseudo-Interface
        Physical Address. . . . . . . . . : C0-A8-00-68
        IP Address. . . . . . . . . . . . : fe80::5efe:192.168.0.104%2
        DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                            fec0:0:0:ffff::2%1
                                            fec0:0:0:ffff::3%1
I believe so btw I've set the nic to get its ip from the dhcp on the router which hasn't made any difference
« Reply #8 on: 29 November 2006, 18:25:13 »
can you type nslookup - this should return the dns server that its using?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #9 on: 29 November 2006, 18:27:29 »
C:\Documents and Settings\John.JOHNS>nslookup
*** Can't find server name for address 194.73.73.94: Server failed
*** Default servers are not available
Default Server:  UnKnown
Address:  194.73.73.94
Weird eh?
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #10 on: 29 November 2006, 18:33:02 »
well the fact that your default gateway and DNS server is the same IP address would indicate to me that you connect via the router - so you'll need to check if that has hard-coded DNS server entries too - if the router is set to dynamically acquire DNS server addresses then you could disconnect & reconnect the internet connection or just reboot the router ...
« Reply #11 on: 29 November 2006, 18:35:36 »
Weird eh?
Very.  What you get if you hard code working dns servers into that client?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #12 on: 29 November 2006, 18:36:53 »
The router is using hard coded dns which I can specify in the config pages but its working fine for 3 other pcs and I rebooted it last night but it didn't clear the prob on that one pc.
Taxi_Driver
« Reply #13 on: 29 November 2006, 18:39:32 »
Is your ISP still with BT?
Coz those ip addresses are BT servers?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #14 on: 29 November 2006, 18:41:01 »
I have tried the same dns servers used on the router and the 4.2.2.1, 4.2.2.2 dns servers but it still gives the same results
