Author Topic: Remote won't resync...  (Read 9833 times)
« on: 13 October 2017, 21:33:02 »
Wasn't working when I collected the car, no led.
Fitted new battery, and lights up when buttons pressed, but does nothing when pressed with key in position 2 as per manual :-\
Re: Remote won't resync...
« Reply #1 on: 15 October 2017, 11:05:13 »
Any thoughts? :-\
    • E250 Est / Elroq
« Reply #2 on: 15 October 2017, 11:22:51 »
from memory the drivers door has to be closed I think, have you tried open and closed?
« Reply #3 on: 15 October 2017, 12:25:54 »
I think so :-\ will try again after work and report back  :y
« Reply #4 on: 15 October 2017, 17:47:21 »
Nope, still not working :'(
    • E250 Est / Elroq
« Reply #5 on: 15 October 2017, 18:06:20 »
hmmm  any sign of butchery of circuit?
Guess you dont even know if it has ever been programmed to the car, blade the same?
« Reply #6 on: 15 October 2017, 18:35:00 »
So I'd suggest never programmed to car ;)
« Reply #7 on: 15 October 2017, 19:17:22 »
Nothing obvious. Buttons on case were battered so new genuine case fitted. Only one key, so nothing to compare with, but works in all the barrels :y
That the LED lights up when either button pressed following new battery suggests that circuiry is intact...
What does this entail?
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« Reply #8 on: 15 October 2017, 20:11:30 »
remove the vehicle battery for 5-10 min then try again, had this on a vectra.
« Reply #9 on: 16 October 2017, 18:21:47 »
*IF* its the right fob (check make on the back and/or on circuit board), then just a carpass and a chat with Tech2.
If its the wrong fob - surprisingly likely - they a new fob (£25 from dealer), carpass and chat with Tech2.
« Reply #10 on: 16 October 2017, 19:38:58 »
If only :'(
If I am going for the car pass, then I may as well get a new fob and second key whilst I am up ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #11 on: 16 October 2017, 20:02:15 »
If only :'(
If you go to the right company, you won't need the car pass. Drive in and out with everything working in 15 minutes. New key included.
« Reply #12 on: 17 October 2017, 09:55:16 »
Don't let them get the vaseline out re programming. Just pop up here and we'll dust off the Tech 2. :y
Chazza12
  • south yorkshire
« Reply #13 on: 17 October 2017, 10:04:10 »
i was looking on a vx site and some one on there had the same problem, and some one said make a call on a mobile and press the button the fob should interfere with the sound on the call or make the screen flicker. as he found out it was the fob not working doing it this way, and took the fob apart and found a dry joint on the micro chip, his is working now. might work doing this i dont know.
« Reply #14 on: 17 October 2017, 12:51:11 »
Thanks Kevin :y I won't be letting a dealer near it  ;)
