Modern DSG gearboxes
Started by Jimbob, 17 September 2018, 06:22:56
Are 3 year old and newer cars with DSG's likely to be ok now?
Assuming serviced and oil changed as required.
I know the older ones had a range of problems.
Older ones have issues. Newer ones might not currently have issues, but at some point they will become older ones.
I would only consider a brand new VAG product with a dsg box, and then only to ensure maximum warranty.*
If you're considering 2-3 year old cars, you need to be aware that the unlimited mileage factory warranty is 2 years, but year 3 is only warranted to 60k miles from registration... So a car that is 25+ months old with 60,001 miles on the clock will have no warranty.
*not that I have any inclination whatsoever to ever buy any VAG product again. Ever.
Quote from: Jimbob on 17 September 2018, 06:22:56
You really want that Skoda, don't you ;)
So far, zero problems with the DSG in mine after 30,000 miles. £18k and I'd part with it...
Viral_Jim
2.5yrs and 21k here, no issues and it's a good 'box imo. Not as smooth in town as a traditional slusher but not bad by any stretch.
Varche
I will crawl out of the woodwork and own up to having one. 50 k miles on the clock when we bought it. Full service history and DSG oil and filter changed at 34k miles. That is an interval I intend to repeat.
I would echo the sentiments about driving. For example it feels "odd" when you floor the throttle. Better to feed it in. having said that violent anything isn't a good driving style. Overall I really rate it
regarding longevity, maybe I had just got worn down by spending a year looking for a second car and life is too short. If we need a new gearbox in 5 years time so be it. We needed a new gearbox on the 2.5 Omega -that was after it was about ten years old.
I wonder if there are any stats on failures per 1000?.
Viral_Jim
Quote from: Varche on 17 September 2018, 09:29:01
That's the problem, the one place where those stats will (may) exist is VAG, and I'll bet they're not for sharing ;). Therefore all you're left with is anecdotal forum evidence where every car is either bulletproof or a total disaster. ::).
I would look for regular oil changes, I think it's every 40k?
So 3 years old would hope it's had at least 1 oil change on the gearbox.
As you know I have full VCDS/VAGCOM, so if you see any down here and they will let you do a diag, happy to do a code read.  :y
Cheers, not set on anything yet to be honest, still reading and looking, but not a lot else is catching my eye bar Superb and Xf
forewarned is forarmed etc so digging before I turn something down with the wrong box.
I suspect some sort of auto is the best way to go for various reasons, although that does go against the grain somewhat.
Quote from: Jimbob on 17 September 2018, 16:42:09.....
You know 2 pedals make sense ....  ;) ;)
