Author Topic: Maths Trick  (Read 2800 times)
M16
  • Lancs
Maths Trick
« on: 18 August 2008, 07:44:08 »
Here is a math's trick so unbelievable that it will stump you. Personally I would like to know who came up with this and why that person is not running the country. ..
1. Grab a calculator. (You won't be able to do this one in your head)
2. Key in the first three digits of your home phone number (NOT the area code)
3. Multiply by 8
4. Add 1
5. Multiply by 250
6. Add the last 3 digits of your phone number
7. Add the last 3 digits of your phone number again.
8. Subtract 250
9. Divide number by 2
Do you recognize the answer!!
Re: Maths Trick
« Reply #1 on: 18 August 2008, 08:30:30 »
Er, no I dont!
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
Re: Maths Trick
« Reply #2 on: 18 August 2008, 08:33:14 »
Home phone number! Clever!
Been there, fallen over it!
Re: Maths Trick
« Reply #3 on: 18 August 2008, 09:11:44 »
Bugger, wish I had scrolled down 1st and seen you had already done it  ;D
Re: Maths Trick
« Reply #4 on: 18 August 2008, 09:14:26 »
Doesn't work with mine because my home No is only 5 number long ::)
I told you Northwich was backward ;D
« Last Edit: 18 August 2008, 09:14:56 by Elite_Pete »
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
Re: Maths Trick
« Reply #5 on: 18 August 2008, 09:32:53 »
Took me 3 attempts to get it right...
kris9128
Re: Maths Trick
« Reply #6 on: 18 August 2008, 10:20:01 »
i'm impressed.  :y :y :y :y :y :y
BazMV6
  • Silverstone
Re: Maths Trick
« Reply #7 on: 18 August 2008, 12:23:21 »
Don't be.  You type in your phone number, add some other numbers and then take them away again.  You're left with your phone number.  ::)
Now if it could tell me the lottery numbers, that'd be another thing...   8-)
« Last Edit: 18 August 2008, 12:24:01 by BazMV6 »
This space left blank for your own message...
Albert1
  • Herts
Re: Maths Trick
« Reply #8 on: 18 August 2008, 13:10:28 »
Doesn't work with my phone number because it's ex-directory...   ;D ;D
Bandit127
Re: Maths Trick
« Reply #9 on: 18 August 2008, 18:03:59 »
It's a good job this bloke is not running the country. Bean counters should never be put in charge of countries, companies or public bodies.
It's  a fact of life. Gordon Brown? QED.
Re: Maths Trick
« Reply #10 on: 18 August 2008, 19:05:34 »
SNAP   ;D ;D ;D ;D ;D
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
Re: Maths Trick
« Reply #11 on: 18 August 2008, 19:43:55 »
Shouldn't stump anyone who can do simple arithmetic!  All it does is multiply the the first half of your number by 1000, shifting it 3 places left, then adds the last 3 digits.
The add 1, take away 250, add your last 3 digits twice and divide by 2 are just distractions.
Re: Maths Trick
« Reply #12 on: 18 August 2008, 19:51:38 »
I knew that ::) ;D
« Last Edit: 18 August 2008, 19:51:47 by Elite_Pete »
Bandit127
Re: Maths Trick
« Reply #13 on: 18 August 2008, 19:56:26 »
Quite. Smoke & mirrors.
Smoke is the big numbers you can't do in your head. Mirrors is the add 1, times by 250 divide by 2 etc.
Try it with your birthdate in DD MM YY format. (e.g 060562)
« Last Edit: 18 August 2008, 19:57:26 by Bandit127 »
Re: Maths Trick
« Reply #14 on: 18 August 2008, 21:20:33 »
I have a 7 digit number and hence why it fails!
2. Enter your number
3. Multiply by 8 (to get it bigger)
4. Add 1 (smoke screen 1)
5. Multiply by 250 (this makes it 2000 times bigger so you dont notice the 3 first digits of your number plus an addition 250 as part of the smoke screen to hide the addition of your last three digits in the next stage)
6. Add the last 3 digits of your phone number (you have now filled in the 3 lower digits)
7. Add the last 3 digits of your phone number again. (add them again so you dont notice!)
8. Subtract 250 (takes the additional 250 off that came about from adding the 1)
Easy enough to do.
Note that most of the steps are so you dont notice that the answer displays any obvious part of your phone number during the calc.
« Last Edit: 18 August 2008, 21:21:18 by Mark »
