Could be quite expensive.
Started by 2boxerdogs, 05 April 2019, 19:03:58
2boxerdogs
Came back from Sussex at the weekend noticed that the clutch was just starting to slip in 3rd gear under load, so now booked in at the dealership on Thursday for new clutch & dual mass flywheel, couldn't risk towing the caravan back so that's in temporary storage at Battle.
Varche
Did they give you an estimate?
ronnyd
dave the builder
Quote from: ronnyd on 05 April 2019, 21:20:58
KY at the ready?  :)
and aftercare clicky   :'(
Bad luck Mr Tilbo
did you not fancy getting the spanners out and DIYing the clutch  :-\
2boxerdogs
Quote from: dave the builder on 05 April 2019, 21:31:53
KY at the ready?  :)
Bad luck Mr Tilbo
No way beyond my capabilities,it's got to be done just got to bite the bullet as they say 😎
2boxerdogs
Quote from: Varche on 05 April 2019, 21:07:52
Spoke to a fellow caravnner about 4 years ago at Sandringham in Norfolk who had just had the clutch & flywheel replaced on his Terracan for £1300 , so I know what to expect roughly always keep  cash in a "slush fund" for things like this fortunately.
Varche
Sounds about right. They are a consumable item.
Had a think about my history of clutches. In my youth I used to change them myself . They were simple and cheaper in those days. Had the 4x4 done and that was 400 with the part 240 of that.
2boxerdogs
Quote from: Varche on 06 April 2019, 08:46:24
Only the 2nd time in 48 years of driving that I'm having a clutch replaced, had about 35 vehicles in total so not bad !
Bigron
WAY back, I did mine on an Austin A30, aligning the friction plate with my special tool - a hammer handle!
Simple job, and it worked fine: happy days.....
Ron.
terry paget
Trouble is, cost of a garage clutch change far exceeds the value of the car. I scrapped Senators as their clutches failed. JamesV6CDX taught me to change Omega clutches, but now the parts alone cost more than the car's value.
2boxerdogs
#10
Quote from: terry paget on 06 April 2019, 11:51:11
Spent £1700 on it last year timing belt brakes + various steering parts belt next due in 2024. So will get this done and when I retire fully in 2022 will replace it with a Landcruiser. Has been a very reliable & useful vehicle has never failed to start first time & has coped with everything I've put it through. 😎
Varche
Quote from: Bigron on 06 April 2019, 11:18:34
Ron.
Those were the days.  :y
Bigron
Yes, especially as I was then of a size that I could actually get under the car! :(
Ron.
2boxerdogs
Quote from: Bigron on 06 April 2019, 13:37:12
Ron.
You & me both 😀😁😂
If you can't fit under the Terracan, you must be portly...  ;D
