Author Topic: Raising jaguar XFR headlights.  (Read 8266 times)
« on: 18 February 2020, 13:14:18 »
Should adjustment be made in a clockwise or anti-clockwise direction?
The neanderthal knuckledraggers  at Duckworth Jaguar lowered the beam to satisfy the MOT criteria. The headlights now shine about 4 feet in front of the car making it dangerous to drive in the dark.
Re: Raising jaguar XFR headlights.
« Reply #1 on: 18 February 2020, 13:42:22 »
It does not give specifics in Topix, best to drive upto next to a wall at night, mark the beam pattern, reverse a number of meters, and set to 10mm below
« Reply #2 on: 18 February 2020, 14:01:34 »
How I've always done it, too. The top of the light (these days) usually has the drop marked as a percentage, too.. so 1.5% drop means 1.5cm at 1m, and so on.
Of course, finding a level enough area to do it is usually the problem! I can just about do the Mini in the garage ;D
« Reply #3 on: 18 February 2020, 14:05:10 »
I do know its 1% on JLR headlights  :y
« Reply #4 on: 18 February 2020, 14:09:43 »
 :y I think 1.5% is me thinking of the Mini headlights (BMW Mini, obviously, not BL with 7" Lucas units .. not that they're much of an improvement, light output wise!)
« Reply #5 on: 18 February 2020, 16:53:55 »
Nah, not out in the country, where its customary to set the drivers side so its like full beam all the time.  And if its a pickup truck, fit a load of 150W spots that you can then use to blind anyone who dares flash...
« Reply #6 on: 18 February 2020, 16:54:12 »
Oh, and drive with fogs on all the time.
« Reply #7 on: 18 February 2020, 20:25:37 »
.. and try to drive your L200 like it's a sports car everywhere. Which begs the question of why you didn't, in the first place, buy a f****** sports car.
.. and relax. ::)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #8 on: 18 February 2020, 20:43:57 »
I was stuck behind a pickup truck on my commute to work today which had its rear fog lights on in perfectly clear dry conditions and refused to exceed 21mph for miles on end. I was fantasising about shooting the driver in front of his inbred family.
« Reply #9 on: 18 February 2020, 22:39:31 »
Is that sort of thing a bit like eugenics?  :-\
« Reply #10 on: 18 February 2020, 22:52:43 »
Certainly a form of educational therapy...
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #11 on: 19 February 2020, 00:10:34 »
Are you one of Dominics forecasting experts?
Migv6 le Frog Fan
« Reply #12 on: 19 February 2020, 00:20:19 »
I had thought of applying,as Im certainly a weirdo. He seems an arrogant little nob though, so I might get fired in the first week for giving him a slap.
Varche
    • Golf Estate
« Reply #13 on: 19 February 2020, 07:31:48 »
Go on then I will dare to ask the questions others dare not ask.
1.Are you a trained MOT tester?
2, Was there a quality issue with the factory settings, i.e. not set as per MDT settings?
3. When you have adjusted your lights up is there a vague possibility that you will then be one of those folk with blinding lights at nightime?
4. Do you do enough driving at night on unknown roads to need 100% lights?
5. Have you had your eyes tested?
« Reply #14 on: 19 February 2020, 08:01:47 »
Some cars lights aren't fit for purpose. Vectra C facelift for example. Adjusted to pass the MoT, they don't actually illuminate the road ahead.
Much like the emissions on your Golf :-X
