Zafira Cooling Module
Started by TheBoy, 16 July 2020, 16:54:14
BazaJT
You must be on a right proper black list[can you call them that these days?] I've never had problems with e-gay.You need select your sellers better
Quote from: BazaJT on 17 July 2020, 20:46:29
This one was selected for me ;D
Quote from: dave the builder on 17 July 2020, 14:50:03
I've got both push and pull fans with resistors here (DE11 Swadlincote ,70 miles from the blast zone Brackley) Free to you if you need either  :y
Is the front (push?) one ident code YS?  If so, when you in?
Front fan is fubar.  Initially, it would spin backwards, but would immediately seize within 5 degrees when rotated by hand the correct way.  Measuring resistance whilst slowly rotating the wrong way, it would go from less than 1 ohm to open circuit.  Freed it up to it will rotate in either direction, but now won't spin in either direction under power ;D.
Trouble is, rear fan (suck?) is reporting the same fault codes, but spins fine with 12v applied to it.  So possibly still a cooling module fault.
Front fan clips into the A/C Condenser at the bottom, and is held on with nuts onto studs on the condenser at the top.  Upon removal, the bottom of the condenser came off with the fan, with definite signs of yellow dye in that area, so that confirms where the A/C leak was ;D.
If a replacement front fan cures the issue, I might just buy a new condenser for about £55.  I might even put some gas in it as well.
Mrs TB is such a lucky woman  :y
45mpg AND aircon :D
Quote from: Doctor Gollum on 18 July 2020, 14:05:41
45mpg AND aircon :D
There is no way that battles will ever get 45mpg. Ever.
I think she achieved 42mpg once over a tank when the Chav was bust she used it for a week. Must have been school hols, when the red rage doesn't hit her ;D
Resistor for rear (suck?) fan is 1.2M.  So guessing thats BFoNTV as well :(
I'm also guessing thats an arse to remove, grrrrr
Quote from: TheBoy on 18 July 2020, 13:39:23
Ignore that, car is off to scrappy.
Quote from: TheBoy on 18 July 2020, 15:09:02
Is it that rotten behind the bumper?
Quote from: Doctor Gollum on 18 July 2020, 15:59:26
Its not pristine, but its not that bad TBH.  I've always wondered how GM got anti corrosion so right on the Zaf-A, yet so wrong on the Omega.
Quote from: TheBoy on 18 July 2020, 16:10:09
Considering the Omega structure is a mid-seventies design, it isn't bad. Way better than its contemporaries  - Granada, E28BMW, Renault 30, CX.
dave the builder
got the bits you need TB , replying to your PM now  :y
Quote from: dave the builder on 18 July 2020, 18:57:40
I think it's being scrapped :-\
*If* the fan is happy only being attached at the top, and given the flawless* test drive its just had with the front fan in the garage, it may get a reprive.
I think some (probably all?) of these fan faults were pre-existing for ages, and went unnoticed.
*gutless, obviously.
