Can't open PC.
Started by Field Marshal Dr. Opti, 20 August 2020, 15:30:58
HP Pavilion 14 inch.
SFA.
Any idea how to fix it chaps?......won't switch on.
Remove the battery and try with just the power supply connected
Quote from: VXL V6 on 20 August 2020, 15:50:40
Done it.....no difference.
Only 15 months old....😢
Auto Addict
Quote from: Field Marshal Dr. Opti on 20 August 2020, 16:39:14
Any lights? Power supply failed?
I like red cars
Have you removed it from the wall?
Try NO power, NO battery (remove it)
Press and hold power button for about 1 minute
Restore power and turn on normally.
Quote from: Auto Addict on 20 August 2020, 17:00:56
Caps lock button continually flashes.....otherwise nothing.
Quote from: Jimbob on 20 August 2020, 17:28:57
Thanks Mr Bob........already done. No go.
Broomies Mate
Hmm another one that took flying lessons?  :)
Quote from: Broomies Mate on 20 August 2020, 22:13:00
Quote from: Field Marshal Dr. Opti on 20 August 2020, 18:24:56
It's giving you an error code;
https://support.hp.com/gb-en/document/c01732674
I think I'm getting 3.2(blink)........but can't find  anything that looks like a memory module......I have SSD does this make a difference?
I have removed the SSD and replaced it.
I still have the 3.2 (blink) code......and the bastard still won't turn on.
Is it likely the SSD unit is shagged?
LC0112G
The 3.2 error code refers to the main PC memory, not the SSD.
Most PC's have the memory in small memory sticks that can be unplugged and replaced. This might be a youTube video to help :
https://www.youtube.com/watch?v=kUxOHTdvAIw
If unplugging and reseating the memory doesn't work then the next step is to replace the memory sticks with something similar or better. If that doesn't fix it then either the connector is faulty or the motherboard is kaput. Either probably means the machine is toast.
Data on the SSD can be salvaged by plugging it into another machine as a slave drive. You might even be able to use the drive as is in another machine as the primary - depends what OS and software you have installed and what kind of security/machine locking is used.
And before playing with the memory, or other exposed electronics, you need an ESP strap.  I'm sure many people will say that they are not necessary, and how they've got away with it...   ...they haven't, they just don't realise it.
