Author Topic: How do I remove this bastard?  (Read 5934 times)
« on: 09 January 2021, 15:22:37 »
I thought it would simply pull out. :(
A couple of wires look like they need replacing. :(
Re: How do I remove this bastard?
« Reply #1 on: 09 January 2021, 15:23:52 »
Are those wires something to do with the fuel gauge/fuel level?
« Reply #2 on: 09 January 2021, 15:46:24 »
Reconnect the battery and touch them together to see if there is current!  :y
« Reply #3 on: 09 January 2021, 15:51:47 »
I've pressed and released the two large plastic clips on the side of the basket but no......
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 09 January 2021, 16:19:36 »
As that's the swirl pot the pump sits in, why do you need to remove it? Fit a new pump to its bracket and reassemble everything.
Insulating the damage to those wires would be sensible
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 09 January 2021, 16:19:58 »
towards the end of this video
clicky
yes those wires look well chewed
has someone or something been there before  ::)
« Reply #6 on: 09 January 2021, 16:53:53 »
clicky
Yes.....I watched this but it didn't show how the basket was removed. Mine seems stuck solid. I want to get it out because it will make it easier to fix the wires.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 09 January 2021, 16:58:32 »
clips look like they go out, not push in if you look at the video
also look at images of the swirl pot and pump on the google  ;)
it's different to the astra ones i have done, they are not attached like that
« Reply #8 on: 09 January 2021, 17:06:58 »
I've tried pushing clips in.....pulling clips out......pushing down......pushing down and twisting in both directions... yanking with a combination  of brute force and ignorance.
My guess is that some f*ucker has used Araldite. ;D
« Reply #9 on: 09 January 2021, 17:12:37 »
I've extracted the pump (looks and sounds like a clit stimulator sex toy) from the plastic casing, so may just buy this if it works out cheaper.
Anyone know the function of the shagged wires?
« Reply #10 on: 09 January 2021, 17:18:58 »
Gauge sender ;)
« Reply #11 on: 09 January 2021, 17:21:28 »
Gauge sender ;)
Thanks......not essential for the pump to work then. Do I have that right?
If it is just for there for the fuel gauge to work in the car I may not bother pissing about.
« Last Edit: 09 January 2021, 17:23:18 by Field Marshal Dr. Opti »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 09 January 2021, 17:23:13 »
if you haven't yet broke anything or do so when you put it all back together  :)
usually all 4 wires go to the multi plug
pump live, pump neutral
level sender neutral or live and sender signal
looks like someone has replaced the sender ,was the damaged wiring trapped by the locking ring ? not going into the multiplug
« Reply #13 on: 09 January 2021, 17:23:40 »
Gauge sender ;)
Technically correct, but having them exposed in the tank is, er, unwise. As is the gauge not working.  ;)
« Reply #14 on: 09 January 2021, 17:25:07 »
The sender plugs into the underside of the cap and exots out of thee top in the flat black connector  ;)
